Televison & Video Logo
Bob Blair Posted on Dec 04, 2019
Vizio E3E420VX 42' has problem powering up completely. Numerous tries will get it to stay on.
carajudibola
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on Dec 04, 2019
carajudibola
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
6
Questions
0
Helped
337
Points
19
3 Related Answers
Anonymous
  • Posted on May 19, 2009
SOURCE: Standby power usage of the 42" Vizio Gallevia?
According to a Cnet review of the 42" Vizio Gallevia, the standby power usage is only .75 watts. Because it is so low, I now have no concern about leaving the set in standby mode. Virtually no savings to be realized by unplugging the set between usage.
Anonymous
  • 9 Answers
  • Posted on May 28, 2009
SOURCE: vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
Anonymous
  • 14553 Answers
  • Posted on Dec 11, 2012
SOURCE: the vizio light comes on as if the tv was turned on / the vizio light does not go dim to bright when the power switchis applied / tried changing power supply board / no change
frankly having it posted as a Sony does not help. Aside from changing a board you did not need to change what other simple steps have you taken? Vizio model number?
Some of the simple things (if you can see Vizio logo and it stays set is on) does it work via a DVD player etc, does it have audio etc.
It is here up to each expert to choose if they want to answer a question or not, with wrong model etc many may have just passed on your question.
If you get the Vizio logo and or OSD let us know that, the more clues the better.
My reaction would not be power supply but maybe just maybe a main board.
I would of course try other signal sources first, remove a cable or sat box and the set from power to see if things change or not.
Up to you how you word the question and what information you provide but up to us to decide if we want to try to help or not.
I personally answer over 400 questions a week so want to help if there is enough info for me do at least try to do so.
It says here zero views of this question which is why I took another look at it.
My vizio wont stay on
Vizio is known for problems very early on. You may have a bad panel or bad driver boards. What is the power light doing when it shuts off? how many times does it blink?
Vizio VP422 won't turn on ORANGE LIGHT PLEASE HELP*
if you plug in the set, and the "Vizio" light isn't orange, most likely you have a faulty power supply board. Tests will need to be performed to be sure.
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney ([email protected])
Vizio vp422 orange light stays on wont power up
I would double check the capacitors on the power supply board. Make sure you don't have any that are bulged at the tops. Secondly, when you try and turn it on, does the orange light flash at all??
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Power is on but nothing responds
The signal board is corrupt! If is under warranty...getter done!!!!
3helpful
2answers
Vizio 42" lcd powers up with sound only - no picture
T.v wont stay on
How old is your set?
Seems like the main DTV board is not initializing corectly. Try the three steps power-On, power-Off, power-On. Do wait for the internal relay to click everytime.
Let us know...
2helpful
3answers
Vizio p42
had the same problem had the main powerboard replaced they were out of stock and had to send mine in and vizio referbed it I was told it was a common problem with this unit
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
