Question about Refrigerators
My countertop ice maker goes through the cycle lke it wants to make ice, but dumps water back in the bucket instead of ice. It is brand new and has only been uses 1 time.
  • 3,514 Answers
I believe I would be taking it back for either a refund or replacement.
Posted on Dec 04, 2019
6ya staff
SOURCE:
Anonymous
  • 237 Answers
SOURCE: Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
Posted on Nov 09, 2006
catriver
Ron Marek
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
Anonymous
SOURCE: Ice maker "ticking" sound?
Mine started doing the same thing. The problem with mine was that the part that spins around to eject the ice is hung up... first, it was trapping an ice cube in it... I cleared the cube and it stopped making noise for a while, then a cube hung up again. Now I found that one of the 'teeth,' all the way to the right, was stuck under the housing... the part is bent, and needs to be replaced.
Check the part that spins to make sure nothing is stuck. Service is expected in home soon (I hope).
Posted on Nov 07, 2008
vonrick33
My lady friend has the same problem with her ice maker. The problem is, the ice tray is broken on the end. I took her ice maker out and found out it was broken. Its going to be hard finding a replacement since they don't make parts anymore.
Good Luck !!!
Posted on Dec 02, 2008
Anonymous
  • 145 Answers
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
The ice maker isn't dumping any ice, the ice maker in on, I can hear it turning but no ice
Your not getting any water to the ice machine. It could have a bad solenoid valve or the feed tube that feeds it is frozen. The feed tube comes through the wall of the fridge and dumps water into the ice try. Pull as much stuff out as you can to be able to see the feed tube. Get a flashlight and see if it is blocked. If it is, get a blow dryer and melt the clog until water flows freely
Jan 22, 2018 | Refrigerators
We replaced the ice maker in our Samsung refrigerator and now we cannot get the water to dispense once we cut the water back on. What do we need to check?
By your question, you are saying you are not receiving water from the water dispenser. Make sure the electrical connector you disconnected when making the ice maker repair is securely re-seated. If you removed the door to make this repair, there is also a connector at the top of the door make sure it is also seated. The only other connection for water or ice delivery is at the water inlet at bottom rear of fridge. There are two relays at the water inlet, one for water, one for ice. If these were disturbed recheck that they were reconnected. Of course these checks should be performed with the power cord disconnected to prevent shock. Once all is checked, plug fridge back in. When dispensing water you should hear a solid clunk as the relay engages. As for the ice dispenser you will only hear the clunk as it requires water to fill the tray. Just remember to allow for two complete cycles (fill - freeze - dump) before receiving full cubes. Oh, by all means don't forget to make sure the Ice bucket full lever (Usually a thick wire) running the length of the bucket Is in the down (empty) position. If it is up, this turns off the ice maker indicating the bucket is full. New ice maker units usually come packaged with the (bailer wire) in the up (off) position.
Hope this info helps!
Dec 28, 2014 | Samsung RS2630SH Side by Side Refrigerator
Ice maker dumping water in ice bucket instead of ice
Replace water control valve. If you have questions please let me know, Thanks John Tripp Appliance 911
Oct 07, 2014 | Fisher and Paykel Refrigerators
Maytag H2O MFI2568AES Ice Maker keeps jamming
Most ice and water units have heater elements inside the door and in the ice chute itself to prevent water and ice from freezing in those areas. Its possible that one of the heater elements has failed. You will need a wiring diagram and a meter to test if the element is OK or not.
Feb 22, 2014 | Refrigerators
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My ice maker has quit making cubes & makes blocks, why?
Good day,
3 possibilities. One is the fill tube that runs from the back wall and feeds the ice maker. If it is not fitting the rear of the wall or resting in the inlet of the ice maker it could cause some if not all of the water when it goes to fill to go directly into the bucket instead of the ice maker.
You need to remove the ice maker (3 screws and a wire plug and adjust the fill tube and check it is not plugged up with ice.
It is a male to female insert, a poor design, o a proper tight fit is important.
The more common problem is where none of the above is an issue, but rather the water valve in the back rear of the machine is not shutting off completely after a fill cycle causing the ice maker to overfill and cause the excess to run into the bucket.
The valve is none repairable and need to be replaced with a new one.
Lastley, I have seen some of these icemakers not shut off after a fill, and continuesly cycle causing this problem. If this is the issue, you will need to replace the ice maker.
You will need to make some observations to see exactly which of the above is the true problem. Patience is your friend here.
Aug 12, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Whirlpool refriigerator ice maker not working
With ice makers it is almost always one of two things. The ice maker itself, or the water valve. Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
May 29, 2010 | Whirlpool GS5SHAXN Side by Side...
Ice maker makes ice but will not rotate and dump the ice.
You have a thermostatically controlled heat release ice maker. Any number of issues can cause a failure to "dump" the ice. The harvest is started when the thermostat closes. A motor rotates the ejector fingers which are at rest in the 2 o'clock position. The ice maker operation will stall until the heater releases the ice from the mold. After the cubes are ejected into the ice bucket, the water valve will refill the mold with water to begin the next cycle. Lack of ice dispensing could be a failed thermostat, heater, motor or switch contact withing the ice maker module. You could simply replace the ice maker and save the expense of the service call.
Dec 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Mar 31, 2009 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
