Question about Stihl Garden
Need help with Chinese knockoff Stihl 066. I'd like a online manual and any videos to replace one broken head bolt an headgasket
    Top Expert:
  • Stihl Master
  • 66,248 Answers
SORRY YOU HAVE TO DO THE SEARCHING FOR YOURSELF WE KNOW OF NOTHING LIKE WHAT YOU ASK BUT USUALLY HAVE TO DRILL THE BROKEN BOLT OUT I WOULD USE LEFT HAND DRILL BIT .WWW.HARBORFREIGHT.COM SELLS THEM
Posted on Dec 04, 2019
6ya staff
SOURCE:
Fred Yearian
  • 5603 Answers
SOURCE: I need to replace the bar bolt on a stihl 011 at
If the bolt is still viable, you could try using two nuts back to back as a jam nut and wrench it out.
If it is not viable (damaged threads) try vise grips. You MIGHT try a bit of heat from a Bernz torch as last resort, and of course penetrating oil like PB Blaster.
Posted on Apr 13, 2010
mclaen
  • 486 Answers
SOURCE: 2002 rendezvous how to replace the headgasket need
The head gaskets on the 3400 engines in these vehicles take quite a bit of time to replace. I believe that the shop time called for is 12.8 hours for federal emission vehicles and 14.4 hours for California equipped vehicles. If you're doing the job for the first time it can easily take way more time than that. I don't have a printout of the procedure or the torque specs but would think that you could get a repair manual at a good parts supply store. You also need to replace the head bolts when reinstalling the cylinder heads as they are a one-time use, torque to yield type of bolt and should not be reused as they won't provide accurate enough clamping pressure if reused. Make sure you have the cylinder heads checked over for warpage, wear, and cracks before reinstalling them. Good luck, hope this helps!
Posted on Jan 17, 2011
philwalker78
Phil Walker
  • 608 Answers
SOURCE: Stihl FS 44 weedeater/trimmer and
Hi, there is a hole down through the top of the gear head. Place a pin punch or small screw driver down through the hole and rotate the head until it locks. Then grasp the head firmly and undo it (left hand thread). Hope this helps, regards Phil.
Posted on May 09, 2011
Nikhow
  • 436 Answers
SOURCE: removing heads and replaceing headgaskets
I can't find them friend but if you are changing head gaskets, then you should really invest in this if you want to 'do it right' It has ALL you need.
http://www.themotorbookstore.com/reliant.html
Posted on Sep 14, 2014
plink_plonk
Plink-plonk
  • 1807 Answers
SOURCE: manual stihl 066
http://www.mediafire.com/view/bk5yfldiqwuoiyw MS066
Posted on Apr 15, 2016
Hello I have a Stihl 066 chainsaw and I am replacing the cylinder what are the torque ratings for the screws?
When installing screws into used components, gently rotate the screw backwards until the threads on the bolt go past the threads already in the component, then start to gently turn the screw in the tightening direction. (the reason is: you do not want to cut new threads, as this will damage and remove the current thread material, and the hole will be too big as a result)
Put a small amount of lubricant (oil, thread oil, ect) and proceed to tighten the screw(bolt).
In this case 11 ft lb. torgue
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Feb 02, 2017 | Stihl Garden
Stihl 066 cylinder to crankcase torque
Put a small amount of lubricant (oil, thread oil, ect) and proceed to tighten the screw(bolt). 11 ft lbs in this case.
Will a 56mm cylinder kit fit a 064
http://sawparts.ca/products/stihl-064-066-ms650-ms660-big-bore-cylinder-kit-nikasil-56mm
It seems that YES a 56mm aftermarket cylinder is available for the Stihl 064. Looking at the kit you need to just replace Cylinder, Piston and rings, bearing bush and clips. Worth also replacing the base gasket too.
May 01, 2016 | Stihl Models 064, 066, Ms640, Ms660
Tension screw won't tighten the chain on a Stihl MS660
remove the cover and look to see if the tab is broken off
Apr 14, 2012 | Stihl Models 064, 066, Ms640, Ms660
Sthil 066 carb diagram
Don't mess with the insides of a STIHL carb, just buy a new one. Why put new parts in an old carb?
Jan 18, 2012 | Stihl Models 064, 066, Ms640, Ms660
Sthil 066 chainsaw
You are absolutely right, an 066 is a STIHL model chainsaw. Good job!
Looking for a parts diagram for a stihl 066 chainsaw
The one with the two right angle connectors is the inlet line. The other is the return line
Nov 05, 2011 | Stihl Models 064, 066, Ms640, Ms660
2002 rendezvous how to replace the headgasket need to replace the headgasket blowing coolant from between the block and head
Jan 17, 2011 | 2002 Buick Rendezvous
Garden Logo
18 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Joe Paxton
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
