You mean the Morse Key?
FT-2000 Brochure - Yaesu.com
https://www.yaesu.com > downloadFile > pdf
PDF
The FT-2000 is the 2nd Generation of the proud lineage of the FT DX 9000 Series, which represented a ... While leaving the pitch of the incoming signal unchanged, as well as "Narrow" notch filter ... on all modules the u-Tune system tracks your operating frequency, ... crafted using a heavy brass alloy (knob weight: 6.7 oz.
FT-2000 / D - Welcome to Yaesu.com
https://www.yaesu.com > indexVS
FT-2000 100 WATT & FT-2000D 200 WATT HF+6 TRANSCEIVERS ... Note: frequency coverage may differ in your country. ... The front panel's oversized 2.67" (68 mm) Main Tuning Knob is crafted using a brass JISC3604R alloy, for easy ...
FT-2000 Series - Yaesu.com
http://www.yaesu.com > products > pdf > AMR
PDF
FT-2000 Series FT-2000D 200 W Version with External Power Supply. FT-2000 100 W ... While leaving the pitch of the incoming signal unchanged, as well as the bandwidth ... on all modules the µ-Tune system tracks your operating frequency, although you ... crafted using a heavy brass alloy (knob weight: 6.7 oz./190 g), for ...
FT-2000 - Yaesu.com
PDF
... transceiver. Before using your FT-2000, be sure to read and follow the instructions in the "Before You Begin" section of this manual. ... each band key accesses three independent VFO frequency/ ... Adjusting the Main Tuning Dial Torque .
SOURCE: INTERCHANGE MODULE
I'm gonna go out on a limb here and assume you are talking about the band modules, right? If so it will accept some in the 6m,2m,and a couple of the 70cm bands. The model numbers I know it will accept are as follows: FEX-767-2,-6,-70A and -70B. If your module is one of these they are interchangeable. BTW, all of these modules are presently discontinued I'm sorry to say. Hope this helps!
SOURCE: yaesu ft 1500 m
Here you can see the schematics http://www.repeater-builder.com/yaesu-vertex-standard/ft-1500/ft-1500m-sch.pdf
The manual can be found on the Yaesu website, http://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=106&encProdID=92FB2363C1E0B9EBC9D3479054E0120B&DivisionID=65&isArchived=1
Good luck,
Gerard
SOURCE: how do i program my ft 2600m yaesu
http://yaesu.com/downloadFile.cfm?FileID=967&FileCatID=150&FileName=FT%2D2600M%5FOperating%20Manual.pdf&FileContentType=application%2Fpdf
Check page 16 and 17 of the manual. It describes several methods depending on whether you have a keypad mic or not.
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
Hi Donald Stevens, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
do you have the free manual for the FT-2000 and read the tuning page. (made 2006, 15 years old now)
you can tune using all modes, if in the right mode, per input.
and yes you can , celled CW, that brass key is really just Morse key, 2 wires and really is just a fancy switch.
this fancy rig has ATU , auto tuner,,, so did you read the page an that here.? page 68+
https://www.manualslib.com/manual/374540...
I strongly recommend read the manual or ask a Elmer class ham, one that knows how to tune any rig.
join a ham club.
if not a ham watch out for MR, FCC.gov and his band of men that fine you using it illegally.
I am licensed Extra class.
or join here
https://www.eham.net/
like me? and ARRL dues?
hint1: of vast tune it into a dummy load first. to learn now to tune. and be sure rig is ok, then try a real antenna. last.
