Purchased dimplex elec stove in 2014, and it's been fine xcept for a grinding noise. That still annoys us but now, it stopped making warm air. Anyway to check that thermal switch or do I have to replace the entire heating asm.??
SOURCE: kenmore dryer model #11060932990
HAVE YOU CHECKED THE IDER ARM UNDER THE BOTTOM FRONT OF THE DRUM??????THANKS
SOURCE: Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
SOURCE: Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
SOURCE: GE JVM1650 Microwave Making Loud Noise
hello Frank. Sorry to tell you that the magnetron is going bad and making that terrible noise. Since the inside of a microwave, even unplugged has up to 2000 residual and deadly volts of electricity I recommend either calling a pro or replacing the unit.
