SOURCE: What size bolts attach tv to stand for Toshiba 37"
You will use the bolts that you take out to remove the base from the tv.
SOURCE: Screw size to mount 32 inch Emerson flat screen?
I don't know, but you can figure it out. It's a sure bet that it's a metric thread. 6mm would probably be a good guess. Could be 8mm also. They're likely fine pitch threads. Take a close look at the back you your TV with a flashlight and take a close picture of the screw hole with a ruler close by that shows up in the picture. Take another picture with a pencil or some other object lightly pushed into the hole. Take the photos and the pencil (or whatever you use) to Lowes or Home Depot and try to match your picture with what you see there. In the hardware department where the screws are, they have rectangular plates on the rack with every size screw and nut for you to see and fit your sample into. Stick your pencil into the holes until you find one that it goes into the same amount that it went into the hole on the back of your TV. You'll figure it out.
If its any consolation, Lowes has calculated that the average project their customers work on requires three trips to their store.
SOURCE: what size screws do I u for Emerson #LF320Em4A to mount to stand
I too am looking for the screw size for a similair TV. Emerson was less than helpful when I called them with the question.
"quote" Since I can not find any info on screw size for the Emerson blc320em9 we think that the TV is not supposed to be wall mounted. "end quote".
This sparkling bit of wisdom was after I had already mentioned the the manual says it can be wall mounted.
Good Luck
