Question about Lands Phones
Speaker button flashing on our phones how do we shut it off?
We have pressed it on and off, unplugged it, and reset the phone.
    Top Expert:
  • Lands Phones Master
  • 55,370 Answers
If pressing the button has no effect, the phone(s) may be defective.
Posted on Dec 03, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Speaker phone light continually blinks
The blinking light on the speaker button means the forward when busy is on. To cancel it- With the handset on-hook dial #12.
Then press your own station number. Then dial # again. The speaker button should stop flickering.
Note: If the SPK button continues to flicker, Forward all is activated. It is the same process as above but use #11 instead of #12
Posted on Mar 12, 2008
Anonymous
  • 43 Answers
SOURCE: flashing light
It sounds as if that particular extension is in Do Not Disturb.
From that phone, try Feature - 69 - Feature.
Posted on Mar 18, 2008
Anonymous
  • 3 Answers
SOURCE: IUniden Max 5 cordless phone with base unit flashes 88
Try a new battery. That is usually what "88" means.
Posted on Apr 20, 2009
Anonymous
  • 407 Answers
SOURCE: placed password shut phone down
Which model are you wanting help with - You mention both the 8300 and 8900?
In any case - The 8300 doesn't have a reset button? On the 8900 it may be behind the battery cover if so you will need a paper clip.
The following advice is general to Blackberry's and will help clear the memory and reset issues - These are both the soft and hard reset.
You can do a soft reset using Left Alt, Right Shift and Delete - Hold down keys simultaneously for a couple of seconds.
If that doesn't work - Try power down, remove the battery for a minute or so, re-insert battery and then power back on.
Let me know how you get on with the above - If they don't work - Can you also clarify which model no as I have given you generic advice for both models...
Posted on Jun 03, 2009
hotratchet
Jac Lawrence Pimentel
  • 952 Answers
SOURCE: Phone won't open, red light flashing.
bring your phone to a local repair shop and have the ROM erased then have the phone software reinstalled.
Posted on Jul 09, 2009
Any way to Factory Reset a JBL Charge 2 ?
Yes, follow this sequence:
1. Turn the device on
2. Press the call (phone icon) and the volume up (+) button at the same time and keep them pressed. After a few seconds the speaker will shut down.
3. Release the buttons.
4. Turn the speaker back on. It will automatically enter into search mode... And there you are, memory wiped up.
Good luck.
Sep 19, 2015 | JBL Charge 2 Portable Bluetooth Speaker |-...
I need to modify the settings of my cisco ip phone 7941
Complete these steps:
  1. Unplug the power cable from the phone, and then plug in the cable again.
  2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. ...
  3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
Aug 04, 2015 | Cisco 7941G-GE IP Phone
Cisco 7942 factory reset
When performing the factory reset procedure we are about to describe, it is important to keep in mind that the IP phone will lose all configuration files and phone applications. This means that it is necessary to have CallManager or CallManager Express setup so that the IP phone will be able to receive the new information (phone application and configuration) after the reset procedure is complete, otherwise it is most likely that the IP phone will not be usable until this information is loaded on to it.
This preparation also happens to be the procedure for upgrading a Cisco IP phone firmware.
Follow the steps below to successfully factory reset your Cisco 7942, 7962 IP phone:
  1. Unplug the power cable from the phone and then plug it back in. The phone begins its power up cycle.
  2. While the phone is powering up, and before the Speaker button flashes on and off, press and hold #. Continue to hold # until each line button flashes on and off in sequence in amber.
  3. Release # and press 123456789*0#.
You can press a key twice in a row, but if you press the keys out of sequence, the factory reset will not take place.
After you press these keys, the line buttons on the phone flash red and the phone goes through the factory reset process.
Do not power down the phone until it completes the factory reset process and the main screen appears.
Oct 10, 2014 | Cisco 7942G IP Phone
Need to reset phone cisco7962
Hi Gtrcop
Restart phone by unplugging power cable
When you see cisco logo press and hold #
The phone will prompt for
Keep network cfg? 1 = yes 2 = no
In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
HTH
-Karthik
Oct 16, 2012 | Cisco 7962G IP Phone
My cisco ip phone 7960 is stuck in boot up mode after performing the soft reboot. i press 123456789*0#
You can try a couple of things: Unplug the power cable from the phone, hold dows the # key, and then plug the power cable in again. The phone begins its power up cycle. Release the # key after the Speaker button is no longer lit. You should see the following message on the phone: "Reset key sequence detected" Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash. If you enter this key sequence correctly, the phone displays this prompt: Keep network cfg? 1 = yes 2 = no In order to maintain the current network configuration settings for the phone when the phone resets, press 1. In order to reset the network configuration settings when the phone resets, press 2.
Or to perform a full reset: Press **#** to reset the Cisco IP Phone 7960
Mar 15, 2011 | Cisco 7910 IP Phone
I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
Jan 18, 2011 | Casio PhoneMate PMP3875BK
My LCD Prostar 816 shows the Speaker light flashing rapidly. When I click on it, it takes me to an Internal Page screen. I can clear out of that, but I get the flashing Speaker light again. This happened...
Aflashinf speaker key indicates that the phone is fowarded.It's either call foward all calls or call foward on busy.
To cancel call forward all calls, press #11 (with the handset in the cradle), then press your own dss button or dial you own extension number (21-36), and press #.
Canceling call foward on busy uses the same steps but uses #12 instead of #11 for the first step.
May 03, 2010 | Samsung Prostar 816 Phone
Speaker light is blinking because the phone was unplugged momentarily
Press the blue function key followed by the speaker button the phone will go through a reset sequence to calibrate itself and the blinking will stop
Nov 20, 2009 | Avaya Definity 8410B Phone
Nec DTerm Series i - Feature Light Flashing URGENT
Thankfully I have found a solution that has worked.
A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
To cancel this setting do the following
Lift the handset or press speaker
Dial the access code 4 + 2 (set as default)
Receive confirmation tone and restore handset or press speaker
I have found the manual at the following link to be the best resrouce ever - very easy to understand
http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Jan 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
