SOURCE: Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
SOURCE: The compressor motor runs for a short time then
you are suppose to have a multi meter and monitor the supply going to compressor, before the overload relay. if the voltage remains while it stop, your overload thus cutting the supply meaning it is overloaded. if the voltage is missing too, the problem is in the thermostat area.
SOURCE: My refrigerator (RB1855) runs excessively long.
There are about four different versions of your model. If you like I will send you the manual and we will work together as this refrigerator is very complex. Let me know, Thanks, Sea Breeze
SOURCE: Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
SOURCE: My magic chef wine fridge keeps making a loud
I have a Magic Chef wine cooler making that loud popping noise - Model # MCWC45MCG Could you let me know the way to fix it if possible or where to take it considering I live near Indianapolis, Indiana?
