Question about GPS
Navi Path Setting - every time I try to set the path it doesn't take. The Please set path keeps coming up when I try tap navigation map. Once at the template what do you do to make it work?
    Top Expert:
  • GPS Master
  • 55,370 Answers
You have to enter a destination before it can function.
Posted on Dec 03, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Memory Navi mode
What you need is an updated Pioneer navigation DVD disc. You can find them here: http://www.pioneerelectronics.com/PUSA/Products/Navigation/UpgradeDiscs/CNDV-70MTP
Posted on Jun 09, 2008
volk1
  • 20 Answers
SOURCE: impossible Firmware upgrade
That path should be location of the file you downloaded from trendnet site. The password is set up password for router. Hope you remember that one.
Posted on Jul 10, 2009
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: navigation path not setting up. on screen message,
I quote this write-up form GPS site...
I have recently installed iGO8 on 2 GPS units - one a Soniq Qnav QNG400 and the other an unbranded unit bought on ebay that had a timed lock on it. Both required slightly different installations that I will share here, to show appreciation for the useful discussions that helped me to successfully install iGO8 on both units.
DISCLAIMER: Do this at your own risk. If you render your GPS unit an expensive paperweight, do not blame me. The first thing that I recommend is BACK UP your files (SD card) before making any changes.
Firstly, I downloaded the iGO8 program and map files (other threads on this site have links to these files, which are updated fairly regularly, so I won't repeat them here).
Soniq Qnav QNG400:
This was given to me as a promotional gift. It came installed with Destinator software and the Australian map was a 2006 version from Sensis, which is dated and forced me to look for more recent maps. iGO8 was my choice.
What I was able to do was connect the unit to my Vista PC via USB. It allowed me to navigate the entire file system, including the internal flash memory. The flash memory contained a file that pointed to the navigation software executable:
\MyFlashDisk\DestinatorApps\DShell\Schema\Schema.i ni (took a while to work out the importance of this file)
1. Back up existing SD card files to your PC if you plan to use the same SD card.
2. If you haven't done step 1, don't go any further
3. Remove all files on the SD card. On mine, it had a directory 'DestinatorApps\Australia' with the map, poi etc. files in there and nothing else.
4. Copy the un-rar'ed or un-zipped iGO8 files to the SD card, using the same directory structure. There should be one folder called iGO8 in the root and under that the iGO8 executable, .dll's, sys.txt file and other folders.
5. The map, poi, language, etc. files should go in their respective folders under \iGO8\content. That is:
- map file(s) in \iGO8\content\map
- poi file(s) in \iGO8\content\poi
- language file(s) in \iGO8\content\lang etc.
6. Connect the GPS unit to your PC and open the Schema.ini file (location given above). There is a section titled [DestinatorBtn], which defines the program that will be executed when the navigation option is selected from the startup menu screen (at least on the Qnav QNG400 running Destinator software). The 'Action' parameter defines the location of the executable. Below is the relevant section with the original Action commented out and the iGO8 executable (on the SD card) defined.
[DestinatorBtn]
Rectangle=0,206,125,62
CaptionRectangle=8,240,111,30
Caption=TxtDestinator
Font=FontDestinator
Color=0,0,0
; Left button -------------
; Original Destinator application (located in internal flash memory)
;Action=\MyFlashDisk\DestinatorApps\Destinator\Des tinator.exe
; iGO8 application (located on SD card)
Action=\SDMMC\iGO8\iGO8.exe
The above details indicate that the original SD card only contained the map files (which explains its relatively small size of 128MB). The application software (Destinator.exe) is in the flash memory. What this means is that without access to the flash memory (to modify the schema.ini file as above), it would be difficult to install/use different navigation software and maps.
7. That's it. Go to the 'Testing' section below.
Unbranded GPS device:
A locked GPS unit was given to me to check out (i.e. try and unlock and/or install iGO8). The navigation software (trial version) was due to expire at the end of this month. It came with basic MobileNavigator software and an Australian Route66 map on a 1GB SD card without TTS capability.
When connected to my Vista PC or an XP SP2 PC, only the SD card files were visible. There was no easy way of accessing any internal files like I was able to do on the Qnav.
This unit required a slightly different installation procedure:
2. If you haven't done step 1, don't go any further.
3. Remove all files on the SD card except 'GpsShell.ini' in the root (specific to MobileNavigator I think). If you delete this, you can copy it from the backup you made in step 1.
4. Copy the un-rar'ed/un-zipped iGO8 files to the SD card, using the same directory structure. There should be one folder called iGO8 in the root and under that the iGO8 executable, .dll's, sys.txt file and other folders.
6. The sys.txt file may need changing, but the one I used contains:
[folders]
app="%SDCARD%/MobileNavigator"
[interface]
maxzoom2d=6000000
show_exit=1
skin="ui_igo8"
vga=0
[debug]
skip_eula=1
[msnd]
msnd.start=0
Note the app directory "%SDCARD%/MobileNavigator". This will be explained after step 7.
7. Since the internal flash memory was not accessible, the button on the GPS unit's main menu that runs the navigation software looks for (and expects) MobileNavigator.
To overcome this:
7a. Rename the 'iGO8.exe' file (in the \iGO8 folder) to 'MobileNavigator.exe'
7b. Rename the root 'iGO8' folder to 'MobileNavigator'
This basically tricks the unit into thinking that MobileNavigator (and associated maps) are installed, when in actual fact it is iGO8 that will be running.
It is also why it is important to set the app folder correctly in the \iGO8\sys.txt file mentioned in step 6.
8. The original card came with an .ini file called 'GpsShell.ini'. This should be copied (from the backup) to the root of the new SD card, otherwise it may not work. I've seen other posts mentioning similar files such as 'shell.ini'. Finding the correct file may require some trial and error for other devices/software, although there would not normally be many .ini files in the root location.
Testing:
That pretty much completes the setup and necessary changes. Insert the SD card into the GPS (if it isn't already) and select the navigation option. If all is well, iGO8 should start, possibly with a few option screens for language etc. and then into the main navigation menu.
I hope this information helps others who need to do similar mods to their GPS/mapping software.
The above ideas should be usable for other units and map software as long as the necessary configuration files have the correct settings and, if necessary, directory and executable file are renamed according to the original software.
Hope this helps; keep us updated
Posted on May 19, 2011
SOURCE: Video card or driver doesn't support the
Hello, the problem seem to be related to the video card you're currently using, See if you have an integrated video card: a hint to find out is to see behind your computer if the monitor connection is on a side of the back panel is probable you have an incompatible integrated video system, you can solve this problem by buying and installing a compatible video card as any Nvidia or ATI card, Call an IT professional and ask for some advice on what card you should buy and install to make these problems disappear, also ask him/her to install it for you.
Have a nice day, and If you have any other questions you can come back and reply.
PD: If you still want to buy and install it yourself ask me again and I'll help you.
Posted on Jun 03, 2011
RONALD CARTER JR
  • 438 Answers
SOURCE: Blackberry 8520 displaying "radio path
hi emily_ashdow go to blackberry dot.com and download the desk top manager on to your computer. The blackberry desktop manager can fix your problem. it will allow you to turn your radio connections
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Posted on Jun 05, 2011
Paper jam at exit
Besides setting it for card stock both in its internal menu and the pc's menu, are you setting it for legal size paper? The timing will be thrown off if that step is missed. It will stop pulling the paper because it is looking for 8.5 x 11" paper. I would test with less expensive card stock to also make sure a shard of the decal paper did not get left in the paper path. The card stock should help dislodge any debris in the paper path.
Apr 01, 2014 | Xerox Phaser 6125 Laser Printer
When I pull up the gps for directions it says it cannot find program. Please set Gps path in file. What do I do to fix it.
Set GPS Path ..
On your Sylvania GPS go to System Setting > GPS Path .This function is to set GPS path for your navigation. Screen display will show asfollows:
File folders of TF card will be listed on screen. Click a folder to open it. Select GPSSoftware If there are two or more maps from different companies on an TF card, then thisfeature can help you select each of them easily. The way to Select: :In TF card directory,open the file folder to find the map to be used, select navigation software of .exe,(whichhas different names from each different company), then select andclicK 10_3_2011_2_45_46_am.gif icon, a dialogue frame will pop up on screen, as it shown below:
Click the accept icon to accept.
Click X icon on the upper right corner to return to GPS path interface.
Oct 03, 2011 | Sylvania SGPD430 GPS Navigator
By pressing Navigation I am ask Please set Navigation Path.I have not idea what to do next.
On my GPS, I scrolled down to and pressed Navi Path, then turned on "Auto run GPS when starting", then set the Navigation Path to Resident\.........\iGO8. It then worked ok.
Aug 11, 2011 | GPS
Video card or driver doesn't support the required fixed-function texture blend operations. DirectX 7 rendering path will not be available. Video card or driver doesn't support direction lights in...
Jun 03, 2011 | Microsoft Windows XP Professional
My Jensen VW9424 Navi unit doesn't keep the correct time. The unit displayed a time 30 minutes ahead of the correct time after installation. Several attempts have been made to set the correct time;...
you have to turn off the gps time there is a setting in the menu that you turn off navigation sync or something like that. Go to setup and nav time. It is whatever setting has to do with navigation time
May 25, 2011 | Jensen VM9424 Car Video Player
I have a Garmin nuvi 1300. Recently i update the firmware, the routing direction keep on showing some path that passing housing area and very difficult to drive though. At the setting is usual like last...
Updating your firmware will not correct that problem. I think your maps may be out of date and does not know what to do. I don't know how long you have had your unit but if its under a year old Im pretty sure your entitled to free updates for your maps. If it over a year old then you need to go to www.garmin.com and purchase new updated maps.
I hope this helps you out if it does please click YES on the web page that you are receiving this response on. Thank you
Apr 10, 2011 | Garmin nuvi 1300 Car GPS Receiver
Hyundai Autonet PND-3520T. Wont navigate.
There is a solution, what is the path of exe file (from the SD card and from internal storage)
Oct 29, 2009 | GPS
My navlink gps says "not find navigation software"
If you haven't already fixed this; try going into, settings, navsetup, - this should give a Path of navigation software line, this line should read: '\StorageCard\iGO8\iGO8.exe' click on file icon at end of the path window "select storage card, select iGO8.exe, select tick to apply then exit.
This works for mine but I assume that if an alternative software is shown in the path window you must choose an approppriate .exe file in the storage card files.
Oct 28, 2008 | GPS
Memory Navi mode
Hi vsudude,
You have to go back to the menu and reset. Youcan take the help of owners mannual supllied along with the unit.
ramesh22
Jun 07, 2008 | Pioneer AVIC-N1 Car DVD Player
Pioneer HD3 (UK) Navi Problems
Go to avic411.com and check, I have seen a post like yours once. Hope you would find it.
Jan 09, 2008 | Pioneer AVIC-D3 Car DVD Player
GPS Logo
23 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
