Hi Fannie-
I found this answer within the Fixya website.
https://www.fixya.com/support/t4629159-singer_futura_ce_200_just_quit_working
I also found this link.
http://futura-support.com/sites/default/files/CE-200%20Manual%20%28Eng%2CFre%2CSpa%29.pdf
This manual is for Eng, Fre, and Spa.
Hope these help.
SOURCE: Other brands of Software
Sorry Dupina you can use other software with the Futura Anita Goodesign, V stitchery and many others, but for the use of Font Software hyperfont is the only one
SOURCE: Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
SOURCE: Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
SOURCE: Singer CE-200 Quantum Futura
i need the 2.5 upgrade software for my futura ce200 because i have windows 7 can i download it off the net??
SOURCE: Futura CE 200 Software Installation Media
Yes, from here: Driver Update Software for XP Vista 7 8 Install this software and make the update. Wish you best of luck.
Peter
