Watches Logo
Sue Messina Posted on Dec 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a women’s Relic watch ZR33535 without a battery in it. What is the correct replacement battery? The person at JCP spent 45 minutes trying to figure out what would work, but couldn’t find one that fit! HELP PLEASE
Terry
Level 3:
  • Relic Master 11,377 Answers
  • Posted on Dec 03, 2019
Terry
Relic Master
Level 3:
Answers
11377
Questions
Helped
4619907
Points
152765
You might try contacting one of many sellers on eBay to ask.
You might purchase a used watch and open it to see the quartz battery inside.
Example for $3.99 on ebay:
https://www.ebay.com/itm/143454663966
5 Related Answers
Anonymous
  • Posted on Aug 06, 2008
SOURCE: setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 26, 2009
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case opener claws. For this yoy need case opener with interchangeable claws. You can buy it on ebay for approx. £7.00.
If the casebask is snap-on, then there shouldn't be any grooves, just small opening (lip) between the caseback and case. This is exact point where the watchmakers knife blade must be inserted and pryed up.
Do not forget to rate, please.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 10, 2009
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 28, 2009
SOURCE: new battery can not reset watch CASIO #2735 Atomic wave ceptor
Did you try this?:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Anonymous
  • Posted on May 28, 2009
SOURCE: Replacing battery on wenger swiss watch
Hate to say it but Wal-mart has the tools; seems like they'll do it for free if you buy the battery
Where to find batteries for relic watches?
Relic watches use common internal movements and common batteries. They can be found at most drugstores, radioshack and jewelry stores. The trick is getting the back off without damage. Best bet, jewelry store.
I'm from India and I have an Relic (Bought from US) the same model but in silver color. Its been almost two years and it is stopped. Whether battery needs to be changed or anyother problem? If I want to...
Most probably its battery problem. You can go to any reputed (Titan, Timex) watch showroom and get its battery replaced. They will change the battery immediately.
Don't get the battery replaced from the small watch repair shops. They don't have original batteries, so your battery will not last long.
Hope it helps. Don't forget to rate me. Thanks for using FixYa.
1helpful
I wanted to replace battery in my wife's Relic watch and a little metal part dropped on the table. I don't know where should it be put back. Do you have a manual for watch ZR33471. I would like to fix...
Thank you for contacting FixYa.
First of all, the manual would not help you with the battery. They usually dont have this info in manual. Your best bet is to take your watch to a local jeweler who does watch batteries. I imagine its just the battery strap but they can help you. You may get lucky and they dont charge you if you have the battery.
Best regards. Jewel
I own a fossil wet relic watch for women "zr 11649-110301.. had the battery replaced but it still will not work.. do u have any suggestions to my problem.. the store i bought it from in nashville Tn was...
I would try to see if you can find another local watchmaker as it probably is something very minor. If you dont have any luck with that, then this is where I would suggest:
http://www.watchrepairsusa.com/fossil/watch-repairs
Best regards. Jewel
1helpful
I have the Relic with the pink face which stopped working. The watch repair at Sears said not the battery, it's the mechanism & wanted $60 to repair. Can I send it back to Relic?
<P>Thank you for cxontacting FixYa.</P><P>You can send back to Relic. I dont know how long you have had, as they do have a 12 yr warranty but you will have to see what restrictions they have on it.</P><P>You can find this info at:</P><P><A href="http://relicwatch.com/warranty.htm">http://relicwatch.com/warranty.htm</A></P><P>Best wishes. Jewel</P>
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 • Watches
Top Relic Watches Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Relic Watch Expert? Answer questions, earn points and help others
