Televison & Video Logo
M
Mark Dubois Posted on Dec 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG55LF6000-UB-BUSYLJR on and off repeatedly
Had tv less than 4 years, and started to blink on and off
Marvin
Level 3:
Top Expert:
  • Televison & ... Master 85,242 Answers
  • Posted on Dec 02, 2019
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29053461
Points
266281
Shorted power supply or other circuit board.
I have a mitsubishi hd 1080 65315 model and the code is 23 what is the problem.
Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
www.stereoandvideorepairco.com/.../MitsubishiShutdownTroubleshootin...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
forum.eserviceinfo.com/viewtopic.php?t=81051
Oct 24, 2010 - 10 posts - ‎4 authors Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
1helpful
2answers
WHAT DO I NEED TO FIX A TV THAT FIRST LOST PICTURE THEN SOUND
Hi Lisa,
Both picture and sound missing indicate a bad main board.
How do I get the picture back on my LG LED 50 flat screen? Sound works, no picture.
-You have a bad panel. Led arrays internal to the panel are defective. Replacement cost exceeds economical repair.
2helpful
How do i link my radio shack gamer-pro remote to my dynex
1. Turn on the device (for example, DVD player) and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/DVD, CBL/SAT, or TV). 3. Press and hold P until the red LED blinks twice, then release.4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2 to 4 and try entering the code again.
5. Aim the remote at the device and press Power (or Play, if it does not have a Power key). The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works.6. Repeat steps 1 to 5 for each device you want to control. For future reference, write down each working device code in a safe place.Code search Method
1. Press TV once.
2. Press and hold P until the red LED blinks twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The remote sends IR codes from its library to the selected device, starting with the most popular code first.
5. If the TV responds, go to step 6. If the TV does not respond, press CH+. The remote will try the next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED blinks twice.
7. To search for other device codes, repeat steps 1 to 6, substituting the appropriate key for the device.
I have the exact same issue as the unsolved problem below on this page: I have a LG 42LC7D that is about 3 years old. A Problem with the LG 42LC7D-UB Television I have a LG 42LC7D that is about 3 years...
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
1helpful
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
6helpful
4answers
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
2answers
5071HD switch, power supply problem??
Pioneer recommended a firmware upgrade for the repeating twelve blue led blinking and remote issue you specifed.
1helpful
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
2answers
Sony LCD projection TV - bulb problem
Hi! sweet123,
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
toprol
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
