Computers & Internet Logo
L
Lee Blansett Posted on Dec 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a LG 50LN5400-UA tv and the leds will not turn on. The powersupply voltage to the leds drops to 76VDC when powered on.
I have a second powersupply that does the same. Are the powersupplies both bad or is the problem with the leds?I can power the LEDs with a seperate powersupply.
Marvin
Level 3:
Top Expert:
  • LG Master 85,242 Answers
  • Posted on Dec 02, 2019
Marvin
LG Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060148
Points
266281
The cost to repair is going to be close to the cost of a new TV.
5 Related Answers
Anonymous
  • 35 Answers
  • Posted on Jun 28, 2007
SOURCE: problem booting
The power supply is your likely culprit. You probably have a bad diode in the power supply. Even if you check the voltages and everything checks out, it still could be bad because voltage checks are done with no load on the power supply. When a diode is bad, a load on the power supply can cause shut down (had the same thing happen to my pc 2 mos ago.) Try a different supply of at least the same wattage rating. If you are still having the same problem, you could be looking at a bad system board. Hope this helps. Good luck.
Anonymous
  • 556 Answers
  • Posted on Sep 22, 2007
SOURCE: JVC TV- MODEL AV-K21T.
it was not necessry to replace so many parts if you go as per proper procedure.please proceed as 1 isolate horizontal output section from power supply & make power supply ok. 2 if it becomes ok check hor osc,driver&h/output section. 3 if it is ok connect power input to hor.section which was isolated. 4 check for loose contact or print. 5 put on tv .
Anonymous
  • 151 Answers
  • Posted on May 24, 2008
SOURCE: powersupply
first you switch on the supply by shorting (green and black )wire in output socket of smps.then check output voltages.If there is no voltage then check switching transistors or protection transistos that is placed on first hit sink.check primary bridge and capacitors for open.
Anonymous
  • 227 Answers
  • Posted on Oct 27, 2008
SOURCE: RECOR COLOR TV dead high pitch whining noise
you have a short in the horizontal ckt,look for diodes,horizontal output it might be damage or a bad cap, if not the fly-back transformer is gone.
good luck
[email protected]
Walter H Boehm
  • 998 Answers
  • Posted on Apr 13, 2011
SOURCE: will not turn on when
Green LED on back of power supply indicates it's getting power. That does not mean that it's distributing the power voltages to the computer. You could have a bad power supply or a bad motherboard. Just to make surethat nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
1helpful
2answers
My TV is a LG 47LN5700-UH I had a lightning strike near the house. Afterward TV would start but not boot completely. Now it won't start at all. Cable box also got fried at the same time.
The led driver AND the T-con board are bad. If you could see a picture with the flashlight then the T-con board would be good. It is not. The led driver can be on the main board or the power supply board. You can get these parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
I have a LG TV, Model #50LN5400-UA , The back light went out a few weeks ago, how do I know which LED Strips need to be replaced? Is it even worth replacing or should I look for a new TV?
Its possible you have lost the voltage that powers the lamps, check that first, voltage on an LG runs about 135 volts per line, if you don't have that unhook the plug going to the lamps and see of you have about 160 volts or higher, if you do then the power supply is most likely ok and you have some shorted lamps and the supply is going into shut down. Sometimes a bad lamp will be dark colored, unfortunately its not a real easy job to get the panel open and get at the lamps, its very easy to damage the panel if extreme care isn't followed.
My LG 50LN5400-UA.When I turn it on there is a flash, then the screen goes dark. The sound works.With a flashlight u can see the picture. I can't see any backlights.I replaced the powerboard.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
I have a lg led tv model 50ln5400-ua no picture but sound on. Before it died it had a little darkness spot in the screen.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
