Discussion on the web site below may give a fix that works:
https://www.ecoustics.com/electronics/forum/home-video/3149.html
SOURCE: Unlock region code
I found this info on the site and it works!!!!
1. Switch on the DVD player.
2. Open the disc tray, and leave it open.
3. On your remote key in the following number: 81328
4. Then press the ENTER key a number of times till region 9 comes up.
5. Press the MENU button on your remote.
6. Finally close the tray.
SOURCE: how to unlock region code for dvd player
Hi, have you tried this? It worked on my LG player.
1. Open DVD tray
2. Press "0000" on the remote.
3. A screen will appear saying NEW REGION CODE displaying the current one.
4. Press "0" for all zones.
5. Press the "select" button on the remote.
6. Close the CD tray.
7. Power off
SOURCE: unlock regional code
I found the solution here.
http://www.videohelp.com/dvdhacks/lg-dv480/10008
Region code hack posted by vassmanov, March 23 2009:
Press the Pause button on your remote control. Using your remote control enter the code 3,1,4,1,5 and 9, At this point, a blue screen displays showing that you are in 'region altering mode'. Press the 0 button on your remote control for Region free. Press the Pause button on your remote control. Power off your player and wait a few seconds. Power on your player and your ready to go!
It worked for me (after a few false starts)
SOURCE: Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units.
Christina Weate
SOURCE: unlock region codes
i fund this by dargan and it worked for me "Def" Camino Real 3, Panama:
Region code hack posted by dargan, August 23 2008:
Same hack for DVD283 worked for DVD-277
<clipped from other post>
Region code hack posted by mhardial, January 25 2008:
DVD Regional Codes
Code Location
**1** USA (incl. territories), Canada
2 Europe (Germany), Japan, South Africa
3 Southeast Asia
4 Latin America, Australia, New Zealand
5 Russia, rest of Asia and Africa
6 China
0, 255, 9 MULTI REGION
Region Code Change
NOTE: Make sure you DO NOT have a disk in the tray while performing the region code procedure
DVD Players
New DVD283
1. Open DVD Tray
2. Press the “Menu” button
3. Press 8888
4. Press the “Display” button
5. Region Code Number shows up. Use the numeric keypad to select your region code number (0 – 6).
6. Press the “Setup” button to exit.
