SOURCE: Bose Wave Radio/CD Model AWRC1P
Yes There is a pigtail fuse in unit. It solders to main board. In order to replace you have to pull main p.c.b to get access to bottom of board.
SOURCE: BOSE WAVE RADIO/CD
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION:
disconnect the set from power before opening the case or poking around
inside. The fuse could be bad, but these sets are notorious for losing
the power transformer. If the fuse is ok then you are looking at a
$100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
SOURCE: where is the fuse for bose wave radio
Upon opening the Bose Wave radio.. 4 screws only from the bottom. The fuse is located at the top side of the PCB. It is a small fuse. Kindly inform me if you need a picture. I am repairing one now
