buy a new blade
if someone tells you they can sharpen the blade make sure the teeth are all even and the disk is rebalanced
In other words buy a new blade the juicer will work better.
BTW why do you think the blade needs replacing ???
The blade maybe was not screwed in right. Screw out the blade using the blade tool and screw it back again making sure it is screwed in and fitted in right. Do not tighten too much. It breaks easily.
Take the top part of the juicer off so that just the shreder is visable. On top of the shreder are 2 small holes on either side of the blades. a handle devise with 2 pins came with the juicer. put the tool pins into the holes and twist counter clock wise. The blade will come off then rest is simple and the unit can be disassembled. If you have lost the tool disassembly will be more dificult but can still be accomplished using a cloth on top of the blades and twiting counter clock wise. Careful though or you will cut yourself
After about a half hour I finally figured it out. I'll go through all the steps.
1. Remove pusher from chute.
2. Pull the locking bar down over the spout.
3. Remove lid.
4. This part is tricky. Stick the orange crescent tool into the blade holes and while holding the filter basket steady with one hand, turn the blade couterclockwise while pulling up.You do have put a little muscle into it. And remember, if you don't hold the filter steady, the whole damn thing just spins.
5. Remove the receptacle.
Good juicer, but it seems unnecessarily complicated.
i had the same problem and figured out an easy way to open it without the tool. DO NOT take out the screws. I simply used chop sticks. I put one in each small hole and held the chop sticks in an X and turned the top counterclockwise!
