Question about Electrolux Ovens
I have a electrolux pyrolux oven with a f239 error how do i clear
  • Electrolux Master
  • 10,749 Answers
    Top Expert:
  • Electrolux Master
  • 66,248 Answers
ASK ELECTROLUX OR GOOGLE IT
Posted on Dec 07, 2019
6ya staff
SOURCE:
Fault F239 Electrolux Oven EVEP6155A Help please
this is an error for the touch controls its often caused by moisture getting into it, there is a strip of foam you fit under the touch panel to prevent it happening, it can be ordered from electroloux
Dec 24, 2016 | Electrolux Ovens
I have an Electrolux Oven EVEP6155A. I have a fault Code F239 showing on the screen Can you please help
this is a error for the touch controls its normally caused by moisture getting on it, theres an upgraded part you can order from electrolux which is basically just a strip of foam you fit under the touch controls to prevent moisture getting in
I have oven electrolux MODL. .EW30IS65JSA ..its has problem error .E35 how I can salve this ??
Hello Awad, thanks for your inquiry!
From what you have described your Electrolux range is displaying an error code of E35. I am not showing that as a valid error code, maybe a digit or the panel is misreading. I would suggest performing a reset on your range to see if that would help clear any faulty codes. You can reset the range by disconnecting the power cord for at least ten minutes. If you continue to experience an issue with your range I would recommend seeking additional assistance from a professional technician. I hope this information is helpful to you. -Matt
May 05, 2016 | Electrolux Ovens
Electrolux oven error code f130.what to do?
Hey Luciano, I appreciate your inquiry!
From the information you have provided your Electrolux oven is displaying an error code of F130. I have researched possible error codes and it appears that this error code is invalid. I would recommend performing a reset on your oven and you can do that by unplugging the power cord for roughly ten minutes. If you restore power and continue to receive the error code can you please comment? I would be happy to assist you further. -Matt
Nov 29, 2015 | Electrolux Ovens
How do I fix Error F 11 on Electrolux wall oven E30EW75ESS2?
Hello Nancy Keller - Typically, error code F11 indicates a shorted keypad. Try resetting the wall oven by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 08, 2013 | Electrolux 30" Built-In Single Electric...
Aeg oven how do you change the bulb?
unscrew the glass. unscrew the bulb
Jan 20, 2013 | AEG Ovens
Electrolux E30EW75E PF code will not clear
that code is letting you know that a power failure has occurred. try unplugging and shutting power off for a few minutes. if that error code still comes on, you may need to replace the control board
May 05, 2011 | Electrolux E30EW75E Electric Single Oven
Electrolux Wall oven E30EW75ESS
Same F23. Resetting the beaker seems to fixed it. Thanks to all
May 27, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Ovens Logo
56 people viewed this question
Top Electrolux Ovens Experts
John Tripp
John Tripp
jdthefixer
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
