Question about Ovens
Where can I get a main oven thermostat for a Diplomat Softline 720g ADP0500
    Top Expert:
  • Ovens Master
  • 30,511 Answers
  • 1 more comment
  • Alex Fleming
    Alex Fleming Dec 02, 2019
    Not available at either. Need a compatible thermostat
  • Andrew Taylor
    Andrew Taylor Dec 02, 2019
    Contact Ransome by phone, they will tell you what is the compatible equivalent. Did you try Belling direct?
  • Alex Fleming
    Yes tried Belling not too helpful, I will give Ransome a call tomorrow, thank you.
    Top Expert:
  • Ovens Master
  • 55,370 Answers
Diplomat would be a possible source.
Posted on Dec 01, 2019
  • Alex Fleming
    Diplomat was MFI NO LONGER EXIST
6ya staff
SOURCE:
Anonymous
SOURCE: Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Posted on Dec 10, 2009
Anonymous
SOURCE: diplomat softline oven with separate grill
grill will not light, door was shut when grill was on.
Posted on Apr 05, 2010
Rene J Solis
  • 1796 Answers
SOURCE: Diplomat cooker model no. adp4230
hI!! THE CORRECT NAME IS: SD1 GRILL ENERGY REGULATOR, cost is £21.61 And to replace it, just watch this video.
http://www.apart4u.co.uk/video-tutorials/cooker-repair-videos/how-to-change-your-grill-element-in-a-bosch-neff-and-siemens-cooker-or-oven.html
Thank You for using FixYa! Don't forget to rate this post!!
Posted on Oct 16, 2010
mrjohnworby
mrjohnworby
SOURCE: I need to set the
If you operate the grill with door closed, cut-out will come into operation and the grill will not light. pull oven out of the wal,l undo the screws that are in the galvanized cover, lift up the cover and press the red reset button. put it all back together & it should be okay.
Posted on Nov 19, 2012
Tom Chichester
  • 55370 Answers
SOURCE: Where can I buy a replacement thermostat for a diplomat mt60 oven. Model number apl5520/21
An appliance parts supplier might have one or can order one.
Posted on Jul 02, 2016
I need Instruction Manuel for A Diplomat ADP3120 Softline 600EM Lamona fitted oven
Google it or ask the manufacturer if they have one available
Sep 09, 2016 | Ovens
I need to set the time on my diplomat softline oven
Sep 14, 2011 | Ovens
Lost manual
Hi,you can download the manual for your unit for free at;www.manualsonline.com or www.manualnguide.com.
Thanks and take care
Apr 19, 2010 | Stoves Premier 720DCa Dual Double Oven
Hi there..
Nov 29, 2009 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Diplomat softline oven with separate grill
Nov 05, 2008 | Ovens
Ovens Logo
63 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
