Question about Husqvarna Garden
My husqvarna chainsaw does not lube the chain why is that?
    Top Expert:
  • Husqvarna Master
  • 55,370 Answers
The oiler could be clogged.
Posted on Dec 01, 2019
2 Suggested Answers
Anonymous
SOURCE:
dontbother10
dontbother10
  • 2220 Answers
SOURCE: Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Posted on Oct 07, 2009
Testimonial: "thanking you"
What can be done to stop leaking oil?
Gary, not sure what oil you are talking about for sure, if it is chain/bar oil it is suppose to leak/lube chain while it is running.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://familywoodworking.org/forums/showthread.php?9424-Are-chainsaws-supposed-to-leak-oil
Husqvarna chain oil leak repair 346
Husqvarna 254 Chainsaw Bar Oil Leak Repair How To Remove Clutch
May 25, 2016 | Garden
Chain and bar gets hot and cant saw straight
this sounds someting like the bar is worn out and now you have to tighten the chain so tight (to keep it on) that it's heating up and makiing things worse, or is auto chain lube not pumping oil up to chain ??? either way if you run long without chain lube your back to reason 1
Feb 26, 2015 | Husqvarna 450 Rancher 18-Inch 50.2cc...
Oil pump 266 xp
The pump or gasket could be bad. Make sure you use only bar and chain lube as this can also effect flow.
Apr 17, 2014 | Husqvarna 266-266xp Chainsaw Piston Ring...
Automatic chain oiler on my Partner s 55 chain saw doesn't work
First check the lines to make sure they are clear of chips. Use only bar and chain lube. If this does not work, the pump may be bad and need replacing.
Feb 09, 2014 | Husqvarna Chain Saw 20" Bar
I have a new 455 rancher chainsaw husky 20inch bar chain keeps coming off new chain
You may have a bent bar, or you could be putting the chain on a little too loose. Perhaps the chain is not getting lube ?
Possible that the chain tentssioner and or adjustment is loosening up as you are using the unit. Other than that maybe a defective new blade ?
Oct 21, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Oil is not lubing the chain on bar, what would be causing it? When using the chainsaw, the chainsaw siezes, and makes the engine run sluggish. The bar and chain we not is not getting oil. The oil...
Sounds like the ports on the bar are possibly clogged with debris or the oil lines going down to the bar are clogged. Check both of them to see if that might be the problem.
Oct 31, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Bar chain oil not getting to chain
Remove the clutch(left hand thread) remover the pump cover and you will prob find the plastic gear U/S Lack of cleaning and lubing.
Jun 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Lou
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Ive just bought a husqvarna 34 husky is this the model number 34? its serial number is 016810 but i cannot find details of it anywhere an want a manual can you tell me mixture also its my first chainsaw,...
Get Chain lube for the chain oiler. Naturally, husqvarna recommends that you use "genuine husqvarna" oil for your mixture, I recommend a quality oil, doesn't have to be husky. Husqvarna recommends a 50:1 ratio, other manufacturers, of vertually all 2 cycle power equiptment use a 40:1 ratio. This mixture is slightly richer, but will not hurt your chainsaw. May produce a bit more smoke. Not sure what a 34 husky is...neither is Husqvarna, I visited the website and even tried to download a manual. Looked at every husky model, no 34.
Jun 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Wayne McNeil
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
