SOURCE: Broken lcd display Nikon sb-800 flash
You can order the part from NIKON or I can fix it for you .
Berrie Smith Camera Repair
[email protected]
SOURCE: Nikon Speedlight SB-800
I had the same problem. You locked your flash by mistake if you have a lock symbol on your LCD. Press the ON/OFF & Sel buttons simultaneously & the lock symbol will disappear. Then reset your unit by pressing Mode & ON/OFF simultaneously for 3 second & you are good to go!
SOURCE: flash is not working for a nikon sb-600 speedlight
zoom the flash all the way in so you can see if the flash bulb is broke
SOURCE: Nikon SB-600. No power on / turn on even changed
Check these important points as shown in the following figures.
SOURCE: my nikon SB-600 doesn't flash at all ?
discharging section of the flash is defective,replace the xenor tube,see that will be flashing.
Testimonial: "Quick response and precise answer..."
