Question about Sharp Televison & Video
How can I add Amazon Prime Video app to a Sharp Aquos LC-80UQ17U
  • Sharp Master
  • 10,730 Answers
Apparently not directly.
Workaround may be to purchase a firestick, which may not be acceptable to you, but is worth considering. Newer tv's add a lot of other apps, but may not be worth the money to you.
Posted on Dec 02, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
nik_warren
SOURCE: I need the 4 digit remote code for a Sharp Aquos
Try 0093 mate.....
Rgds,
Nik..
Posted on Jul 24, 2010
vuduc_pham
vuduc_pham
SOURCE: Need user manual for 42"sharp aquos lcd tv
INTERNET CONNECTED
Posted on Jan 28, 2012
Batman1972
SOURCE: I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
my la22a450c1 has no sound and picture . what's problem ?
Posted on Feb 10, 2013
The screen shows the lock mark and has changed color and can not change any sitting and we don’t have remote control
HCDZ Replacement Remote Control For Sharp LC-70LE732U LC ...
https://www.amazon.ca/HCDZ-Replacement-LC-70LE732U-LC...LC.../B00F3ZFA6QHCDZ Replacement Remote Control For Sharp LC-70LE732U LC-46LE830U LC-70LE733U LC-80LE632U Smart AQUOS PLASMA LCD LED HDTV TV: Amazon.ca: Electronics.
You need a remote, but just try disconnecting it from the mains. That might get rid of the lock symbol. The blue hue is a fault and you need a television engineer or a new television.
Mar 18, 2018 | Televison & Video
How do I add youtubetv app to my Sharp 55in P7000 series tv.
Connect your AQUOS LED SMART TV
After about 3 minutes on the video above, it leads you to the SmartCentral app, which should let you add youtube to a Sharp TV.
Getting Started with Sharp SmartCentral
Jan 28, 2018 | Sharp Televison & Video
C3742U. Where can I get a replacement power cord?
If you mean the Sharp LC-C3742U TV, the power cord is part number: QACCDA039WJPZ . Several vendors have the power cord, including Amazon.com. See http://www.amazon.com/SHARP-OEM-QACCDA039WJPZ-CORD-CORE/dp/B001DEJTN6 and https://www.partstore.com/Part/Sharp/Sharp/LCC3742U/Sharp/Sharp/QACCDA039WJPZ/New.aspx, among other links.
I hope this helps.
Dec 18, 2015 | Sharp Aquos LC-13B6U-S LCD flat panel TV...
How do I add the Hulu app to my Sharp Aquos TV. Model number LC 60LE632U
on the tv go to your browser in your menu, then go to hulu.com, then see if you can save that site.
Sep 09, 2015 | Sharp Televison & Video
BEST PICTURE SETTINGS TO WATCH MOVIE
Quality is in the eye of the beholder. Female have 2 times the color receptors in their eyes so they tend to be more particular about colors. Adults over the age of 19 begin to yellow their eye lens until brightness and contrast become a major issue as young as 40. And critics don't mind offering their opinions especially on TV settings. The easiest way to gain their incite is to google the "manufacturers name" followed by the "model number" and the word "review". Good luck.
Mar 12, 2015 | Sharp LC 80UQ17U 80 inch Aquos 1080p
I LOST MY POWER INPUT CORD FOR LC-225VTU
Tries Partstore.com,if out of stock,buy it on Ebay.com or Amazon.com plug use in playstation 1,2 use the same plug.
Nov 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
