Question about Vacuums
My Gtech airam K9 handle is stuck in the upright position
6ya staff
SOURCE:
Anonymous
  • 7 Answers
SOURCE: No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
Posted on Nov 07, 2007
Anonymous
  • 83 Answers
SOURCE: handle wont go to upright position
The red pedal has slipped out of position. On both ends of the red pedal you'll see metal rods (the axel of the pedal). On one side you'll see the metal rod sits into a long groove, on the other side you'll see the metal rod sits into a round hole. They both have to be in the long grooves so you have to reposition the rod that's into the round hole by pulling it out and sliding it back into the long groove above the round hole. You'll now be able to bring the handle up and lock the machine back into the upright position.
Posted on Jul 30, 2009
Anonymous
  • 34 Answers
SOURCE: handle relase stuck
dirtdevil vacuums are so cheap. it's jammed. just go to a vacuum shop and get it repaired
Posted on Sep 12, 2009
Anonymous
SOURCE: dyson 28 handle is stuck in the locked and upright
how do you remove the air duct (plastic sliding piece) that is making the vacuum stay in locked upright p[position?
Posted on Mar 09, 2010
Anonymous
  • 167 Answers
SOURCE: Placing the handle of my Dyson DC07 into its
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
Gtech Air Ram jammed in upright position after red lights came on frred the cause but cannot now put it in the cleaning position
Thankyou loads, the lady of the house asked me to fix the handle, sure I said ! Ha, having taking all the screws I could from machine and getting nowhere I got on the net, your information was spot on and easy to solve, spray some lube whiched worked in seconds, put screws back in , works perfect handle works a treat and hover works. Um ! I've two black screws left over ? Reminds me of my air fix days .thankyou
Aug 18, 2018 | Vacuums
Handle will not go down - stuck in upright position
Make sure there is not any debris stuck in the valve pipe assembly which will keep the assembly from switching from tools to floor.
Oct 27, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
Bissel cleaner won't stop spraying water
Remove the handle and check for continuous spray.
After handle is removed, check to make sure the valve is not stuck in the down position. If the valve is stuck in the down position, push on it manually to get it to come back up. If it is stuck you may need to get a new handle for your unit. This handle is for a variety of the ProHeat models http://www.bissell.com/parts/?sc=part&productid=2775&partid=4449&cid=ccsocial
Check to make sure it will properly fit your model if you need a new handle.
May 08, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
The handle will not release to lower the handle it is stuck in the upright position dc 28 animal model
Sorry to hear about the problem you're having with your DC28. You should find the cleaner reclines into the vacuum position easily when you place a foot on the cleaner head and lower the handle. If it's not doing this, please get in touch with us free on 1866MYDYSON, or email askdysonUS@dyson.com. One of our experts will be happy to assist you further.
Kind regards,
Jack
Jul 23, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Handle wont go to upright position
Jun 17, 2009 | Dyson DC25 All Floors Bagless Upright...
The shut off switch is stuck to the on position
This sounds like you have an internal problem with the electrical switch. I would recommend you take it to a vacuum dealer who has experience with this model. This is a relatively simple reapir for a pro shop to handle.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 13, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
