Garden Logo
B
BILL IDEKER Posted on Nov 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The seat safety switch shut off the engine & now it won't start. What do I need to do to get it started. It's a ztr RZ5424
CJ Rock
Level 3:
  • Garden Master 4,429 Answers
  • Posted on Dec 01, 2019
CJ Rock
Garden Master
Level 3:
Answers
4429
Questions
0
Helped
1644493
Points
15024
For starter to engage all the following are needed. Arms OUT, Brake ON, and PTO OFF.
Cycle all the safeties i.e. move Arms in to out. Brake to off then on. PTO on to off.
If it cranks but doesnt fire it could be seat switch or other.
Dariusz Zalewski
Level 3:
  • Master 1,095 Answers
Dariusz Zalewski
Master
Level 3:
Answers
1095
Questions
0
Helped
297437
Points
3055
Probably switch is bad and should be replaced. Temporarily you could short wires going to the switch but you have to remember that you no longer will have that safety feature and machine could be started without operator on the seat or could drive itself when operator is no longer on the seat.
5 Related Answers
Anonymous
  • 154 Answers
  • Posted on Jun 13, 2009
SOURCE: seat safety switch on cub cadet z force 50
you could splice the wires and by pass the switch all together.
Joel Friedenberg
  • 1114 Answers
  • Posted on Jul 07, 2009
SOURCE: Started up...then died as if safety switch 18HP craftsman rider
On later models there are possibly three safety switches, one under the seat, one for the blade engage mechanism or blade clutch so the blades don't turn when the mower is started, and a neutral safety switch to make sure the mower is in neutral before it starts.
Anonymous
  • 496 Answers
  • Posted on Sep 16, 2009
SOURCE: Cub ztr 50'' with 22 hp Briggs. PROBLEM: Engine
Need more info...
When it dies, does it crank back up? if not, at this time, you could check for spark. If none, you might be on track with a fault in a switch.
But if you have spark and it doesn't crank,
check for condesation in the gas (carburator and fuel tank). If any, problem solved... drain and dry carb bowl and gas tank to insure all trace of water is out.
Hope this helps... Good luck!
Anonymous
  • Posted on Mar 16, 2010
SOURCE: 96 jetta gl buddy put in a 95 transmission....won't start in park
i have aproblem with my 95 jetta 2.0 it will only drive in reverse
Anonymous
  • 146 Answers
  • Posted on Jun 04, 2010
SOURCE: electrical problem
Strange as it may seem, if the mower dies when the brake is released, the problem is in the seat switch circuit. The safety circuits are designed to let you start the engine even if you're not in the seat, as long as the brake is on and PTO is off. While it might be the seat switch again, I'd also look at the the switch mounting or adjustment. If out of adjustment, it won't operate even though you sit in the seat. Also I think the associated wiring and connections to the seat switch may hold your problem.
If you're up for troubleshooting it yourself, try this:
Get an automotive test light (10 bucks or less). Clip the black lead to the negative battery terminal. Touch the pointed test probe to the positive battery terminal to confirm the tester is actually working. Lights up? OK, onward. Note that the pointed probe can be touched to a connection, but can also used to pierce through the insulation of a wire to test it.
Examine the wiring to the seat switch. One wire will go to a relay - a black module the size of an ice cube. Call that the "relay wire". The other should go to an area with several connections. Call that the "hot wire".
Engine off, nobody sitting in the seat. Turn the ignition on -- don't crank or start the engine, just turn the ignition switch to the first position. Probe into what we called the "hot wire". The test light should go on. If you can't get it to light, that wire or its associated connections is probably bad.
If the "hot wire" is, as they say, "hot", then probe the other wire to the switch -- the one we called the "relay wire". You'll have to operate the seat switch manually, or put tape over the button to keep it operated. The test light should light up, and if so, the seat switch and its connections are good. If not, then the seat switch or its connections are bad.
If everything's good so far, tape the seat switch in the activated position while you trace along that "relay wire" to where it connects to the relay. Perhaps the connection at the other end is loose, or the wire broken off inside the insulation. Use the probe to test along it and to test the relay terminal where it connects.
I hope this has been of help. If so, please rate my answer, thanks and good luck!
1helpful
Riding mower battery test shows 12 volts still won't start mower.
Typical engine start safety circuit for a rider tractor mower requires PTO off and brake on. Some require operator in seat.
Cycle the switches and try again
PTO on/off
Brake off/on
ZTR mowers require PTO off, brake on, and steering arms out. Some require operator in seat.
Mar 07, 2022 • Garden
Wot can it be when i start my toro up and lower the hand break then it switch off
ZTR mowers will kill the engine if the operator seat is not occupied and the brake is released. Likely you have a failed seat switch but could be other... it will depend on the particular Toro model.
Apr 26, 2019 • Toro Garden
Will not fire, turns over...like no spark
Check to see if there is a safety switch under the seat. This shuts the mower down if the rider falls off for safety. You can test the switch by unplugging it and jump the connections together at the end that is attached to the engine. If it runs in this condition you need a new safety switch in the seat.
Engine starts fine. When you try to go forward by pulling in the levers from neutral position, the engine goes dead. Seems like it is a safety switch? RZ5424
Sounds like the safety switch in the seat has went bad and doesnt think your in the seat. Someday they will be forced to be responsible how they use the safety switches on mowers. A cluster of led lights to tell us which switch is not happy would be the answer. Some of the switches are closed when in the seat and some are opened. Start with lifting the seat, switch should be in the center on bottom side and unplug the switch and try it, then if that dont work put a paper clip in the two spade holes on the wires that pushed over the seat safety switch so they are connected to each other.One way or the other it will bypass the switch and know you are in the seat.
Mar 23, 2016 • Garden
How do I bypass the seat safety switch on a 5424 Husqvarna zero turn mower?
ether unplug it if wont start then jump the wire pigtail with a wire you can bypass both switch like this
2answers
Mower will not start, tried to jump.
Make sure:
Blades are disengaged
parking brake set
If it has the tillers (as opposed to steering wheel) make sure they are both as far out as possible
I have a Husqvarna RZ5424 and when I was mowing the other day it shut off and has not started since.... the 20amp main fuse was blown so I replaced it but still wont start.... all the safety switches are...
I just solved my problem with mower was completely dead. The wiring harness runs under the battery above the rotating pulleys for the mower deck. Must have been a branch or something got caught and severed through one wire completely and partially through the others. I spliced and taped everything and it works for now. Poor engineering in my opinion. May have to get new wiring harness at some point. They run about 64$ on amazin
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
