SOURCE: TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
SOURCE: No signal converter box.
Why is this in the computer section?
Anyway, don't exchange the box just yet! First, can you access the converter's menu? Because mine automatically comes up with the "no signal, call customer service" message, but I can access the menu fine -- so the hook-up is not the problem. If you can access the menu, let it autosearch for you, because mine can't be used until I do this. If you get the "weak antenna signal message", refer to the user manual to find out how to check your antenna signal strength; if it's in the weak range, you have to buy a better antenna, most likely from the official source: http://www.accessHD.tv
You can always exchange the box and repeat the process. Getting the "no signal" message is a good indicator that you've hooked everything up right, especially if it's accompanied by a customer service number. You can email me at [email protected] and I'll try to help you troubleshoot the problem if you like. I'm up all night.
SOURCE: Black box appears on tv screen
Check to see that you don't have any channel locks or parental parental permission measures deployed. If so remove them, this includes V-Chip, and Parental lock out on the remote, and check your TVs menu items. What channel are being affected by this problem? Give channel number and channel type.
Thank you,
Shuttle83
SOURCE: Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
SOURCE: audio box flashes on screen {mono/stereo}
For some using composite wires instead of the coaxial may not be a possible because you use the red,white,and yellow spaces for your xbox or playstation. Here is another solution if you use digital cable or a similar cable box. This may work for many other cable boxes. Go to your cable box's settings and look for an option to change your "Audio Range". which is probably right now set on either "normal" or "narrow". If this option is on "narrow" then change it to normal and monitor the results. If you continue to recieve this problem then change the setting again to "wide". This should eliminate the box all together. If anything you might only see it once or twice in the entire day instead of ever 20 secs like mine was. I sincerely hope this is helpful.. Let me know.
