Question about Bernina Sewing Machines
Why is my Bernina 640 sew for a minute then stop, then I press the escape and so a minute it happens again.
    Top Expert:
  • Bernina Master
  • 66,116 Answers
I WOULD TRY THE BERNINA WEBSITE FOR TECH SUPPORT
Posted on Dec 13, 2019
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
Posted on Apr 11, 2009
Linda Price
  • 244 Answers
SOURCE: Bernina Artista 640 - While embroidering, the
This will probably need to be handled by a professional. With this particular Bernina, you might be able to adjust the needle position so that it is slightly off center and will not hit the presser foot. That would be a temporary fix, however. If you want to be able to thoroughly enjoy your sewing time, you will be happier if you take it to a certified Bernina repair site and let them adjust the needle position.
Posted on Nov 11, 2010
relicssmm
  • 20 Answers
SOURCE: Bernina 1080 while sewing normal stitch, stitch
What stitch to you have selected for it to do? Please check to see if it is set for straight stitch only.
Linda at Relics
www.sewing-machine-manuals.com
Posted on Jul 05, 2011
Rick Beament
  • 166 Answers
SOURCE: with the bernina activa 230, it will randomly stop
Unfortunately this could be a number of reasons, ranging from simple to hard. Taking the simple first - make sure the 2-pin plug is properly inserted into the machine - if it stops, try wiggling the plug first to see if that 'resets' the machine. If it's OK, it might be the switch on the power supply - I've had a couple that needed replacing, but in all honesty, the problem is probably internal and could range from a poorly-inserted plug on the main control board, to a component problem on the board itself, which could be costly to replace. Is your machine still in warranty (2 years on electronic parts) - if-so, get it checked-out by your Bernina service agent, just in case ... dont go messing-about with the machine yourself. Before doing this ... check exactly what happens when it stops sewing ..... I assume that the foot controller doesn't make any difference ..... check if the sewing light is still on, or the display backlight, and is the display still showing any information, or has it gone blank ? Does it happen on all patterns - straight/zig-zag etc. or a memory pattern ? This may help to identify the likely cause.
Posted on Oct 27, 2011
SOURCE: My bobbin case jumps out while I am sewing on my bernina 1008.
it sounds like the bobbin case needs to be replaced, have you cleaned under the needle plate & bobbin area for lint & loose threads
I also would suggest to take the machine to a different sewing machine repair shop.
Posted on Mar 06, 2012
I need the rotary hook only for a bernina 850 can anyone help me
Fixya does not sell rotary hooks and is not a buying service.
Nov 03, 2016 | Bernina Sewing Machines
I want a diagram for oiling my Bernina 640 sewing machine
Hears the first video that came up on a youtube search: https://youtu.be/hJCRfpO_MVo
Nov 02, 2016 | Bernina Sewing Machines
How to Turn Off the Bobbin Sensor in the Bernina Artista 640
make sure you're using the appropriate bernina bobbin, others can confuse the sensor. This video(by Bernina Boys) shows how to clean lint to prevent this problem which is what often causes this error. Or go into settings by pressing the diamond with right hand arrow inside of it. The eye with the speaker next to it should get you where you need to go to turn it off.
The manual on Bernina's website is here:
https://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/artista/Manuals/031508-50-04_0601_a640_EN
page 98 has the information you want.
Jan 22, 2015 | Bernina Sewing Machines
Why does machine sew then stop after maybe 8 or 10 stitches?
You obviously have a faulty machine take it back to your dealer where you bought or directly contact Bernina.
Best wishes.
Aug 21, 2014 | Bernina Artista 640E Sewing, Quilting and...
Can you tell me what the bobbin image on the artista 640 means? It will only sew for a few stitches and then stop
Hi, most likely your bobbin sensor is being blocked by something. Common causes are a dirty sensor. Q-tip on the eye of the sensor inside the bobbin door. Or there is fuzz blocking it. Next take out the bobbincase and the bobbin. Look in the bobbincase and you will see a round spring. This spring acts like a brake for the bobbin. Sometimes these springs will get moved and out of position blocking the little space that the bobbin sensor reads through. Reposition the spring so you can see through it and the bobbincase.
That should do it.
Good luck.
Rick Engel
Bernina tech
Mar 02, 2010 | Bernina Artista 180
How to find out usage on my Bernina 640 w/embroidery
For a 640: Make sure the machine is off then Press the reverse button and the needle up/down button at the same time and keep pressing while turning on the machine until the service screen come up. Select the "i" icon and then the icon that has a picture with the clock and a question mark. That will show you the hours and stitch count used. To exit the service program just turn off the machine.
Jun 14, 2009 | Bernina Artista 180
Mar 26, 2009 | Bernina Artista 180
Bernina artista 640 embrodry
.g_thread_answer { overflow:visible !important; }
Jul 29, 2008 | Bernina Artista 180
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Chris Wetmore
Wayne Buss
Harjeet Singh
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
