Question about GE Microwave Ovens
GE Profile microwave blew circuit breaker. I reset breaker but still no power.
    Top Expert:
  • GE Master
  • 55,370 Answers
Internal fuse may have blown
Posted on Nov 30, 2019
6ya staff
SOURCE:
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Posted on Sep 10, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: microwave won't heat
Sorry my Clarification Request came out as a single blob of a paragraph.
That's not how I typed it. I never write that way!
So I've pasted it here, but as a solution.
Magnetrons generally should last about 2000 hours, but several factors can shorten that.
If it's not OVER ten years old (from the purchase date or the date on the tag inside the unit) then the magnetron is still under warranty.
From the owner's manual:
"For the second through the tenth year from the date of original purchase
"The magnetron tube, if the magnetron tube fails due to a defect in materials or workmanship. During this nine-year limited warranty, you will be responsible for any labor or in-home service costs.
"For the above limited warranty: To avoid any trip charges, you must take the microwave oven to a
General Electric Customer Care® servicer and pick it up following service. In-home service is also
available, but you must pay for the service technician’s travel costs to your home."
GE Customer Service is here, and you can verify the warranty status and find your nearest authorized servicer.
If you're sure the magnetron's bad, it's still under warranty, and you or a friend are handy, they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
It does sound like the magnetron overheated and the magnetron's thermostat opened until it cooled down.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
Since yours is a counter top model, there are less of those factors to worry about.
When you hit Start to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
You can find helpful exploded view diagrams and order parts if needed by entering your full model number from the tag on the oven here.
Let us know what you find out or decide.
Posted on Jul 07, 2009
Treefrog15
Treefrog15
  • 130 Answers
SOURCE: How do you reset the microwave power? Is there an
There is an internal cartridge fuse, as well as thermal fuses. It is not recommended that you attempt any internal repairs on a microwave due to the presence of very high voltages and the danger of microwave radiation if not reassembled correctly. Residential microwaves, if not under warrranty, are generally considered disposable. Parts and service are very expensive.
Posted on Feb 25, 2010
Testimonial: "Thanks, that was very helpful."
SOURCE: GE Spacemaker microwave JVM140G just stopped
NO internal fuse. It is most likely, the magnetron, and or High power diode. As related In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on May 10, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Our two year old GE
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101//
Posted on Mar 15, 2011
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
Sep 24, 2017 | GE JVM1750DM Microwave Oven
My ge profile spacemaker II microwave went dark, no lights of any kind and no sound or response when pressing any button. tried resetting the circuit breaker but no change
Did you check the internal fuse? Often when everything is dark the fuse that protects the microwave is blown. Take the old fuse to your local hardware store and they will have a replacement for you. Should cost less than $5.
Nov 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile space maker xl 1800 shut down during cooking
Unplug unit..reset circuit breakers..check agin and then see if it starts up. It may need drying out due to excess steam
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My daewoo microwave/toaster blew my breaker upon resetting it and plugging in the microwave it blew again then it tripped my GFI what could be the problem?
Probably a short inside the microwave circuitry.  I had a Daewoo and had nothing but trouble with it.  Main board went out in a year, then again in another year.  Finally went to Home Depot where I bought it and was told that they had nothing but trouble with them and quit selling them.  Now I have a GE Spacemaker.
Apr 22, 2009 | Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
