SOURCE: need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF]
Cox Manual
File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
www.xdiv.com/remotes/ - 73k - Cached - Similar pages
www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
SOURCE: how to hook up a kenwood audio-video surround
hello all you need is a good pair of RCA cables.
Use the audio output on the TV
run it to the VIDEO 1 input on the receiver
as for your DVD player vcr etc you can either run them directly to the tv as it will output whatever sound is playing to the receiver.
or
use the receiver as a video switcher and connect your components directly to it.
remember your receiver will need to be set to the input you use. ie: video 1 / dvd etc..
Hope that helps
SOURCE: I have a 21.0 IR/UHF
bigfootbuz
I have provided instructions on how to program the remote to other equipment. If you have any other questions, please don't hesitate to ask.
Address To Other Equipment Using Power Scan
Then Press STAR (*)
SOURCE: I have and old kenwood audio video surroundsound
Have you tried the stepnset: (instructions from directv's website)
There is no other setup code indicated for your product
that links to the model number you entered.
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
Set the "Mode Switch" to the desired mode such as TV for a Television.
Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
Enter the code "991" followed by the "device number"
1 for Televisions
2 for "AUX 1" devices - VCRs or DVDs
3 for "AUX 2" devices - Audio
You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
You can try out each code by pressing one or more function keys such as power, volume or digit keys.
When you've found the setup code that works for your device, press the "Select" key.
Hi Randy Hartle, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
