Cell Phones Logo
chanda farrell Posted on Nov 30, 2019
My BlackBerry 10 won't make notification sounds
Master Genjie
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Dec 02, 2019
Master Genjie
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
9645
Points
30
Try to turn the volume up
if it doesnt work you have to do an HARD RESET, hard reset will erase all the files in your phone
Iphone task and calendar alerts disappear when I enter password
Depending on the OS you are running they are in Notification Center(iOS 6 and Later). You can access Notification Center by swiping down from the very top of your screen in iOS 7. You can change Notifications on an app by app basis in Settings, Notification Center.
Hi, my bb9000 consumes battery very fast please advice what should i do in this regard?
Instructions
    • 1 Turn off your wireless and Bluetooth when they are not in use. If you leave your wireless settings on, your phone is constantly looking for a wireless connection, even if one isn't readily available. This eats up battery power. Touch "Manage Connections" from your home screen and select "Off" for wireless connection. Then turn your wireless on when you know a connection is available.
    • 2 Close applications when you're finished using them. Leaving applications running uses memory and battery power, especially if those applications send you frequent notifications, like Facebook. Once you're done using an application, use the Blackberry button and select "Close" at the bottom of the menu to close the app completely and avoid notifications until you open the app again.
    • 3 Use your applications wisely. If you're running short on battery life, it may not be a good time to run Google Maps or other applications that use a lot of battery power. In general, battery-consuming applications are those the need a constant internet or data connection and cause you to receive frequent notifications.
    • 4 Change your vibrate notifications so that they occur less frequently, and use audio notifications when you can. Vibration actually uses more battery life than a ring tone. While you may need to put your phone on vibrate when you need to use your phone discreetly, shortening the amount of vibration notifications you get can conserve battery life. Choose "Options" from your home screen, and then "Sounds and Ringtones." Choose "Ringtones" from the drop down menu and select the type of ringtone you want. To decrease the volume of your vibration -- and therefore the power you use -- press the volume buttons on the side of the phone when the phone is in vibrate mode.
    • 5 Decrease the backlight timeout, which keeps the keys on your Bold lit for a specified amount of time after you stop using them. The shorter the timeout, the less battery power you'll waste. Visit "Options" from your home screen and then choose "Screen/Keyboard." Adjust the backlight settings so you only have three to five second before timeout and the backlight shuts off. You can also use the settings to dim the backlight to use less power.
Read more: How to Optimize My Blackberry Bold's Battery Life ' eHow.com http://www.ehow.com/how_8087565_optimize-blackberry-bolds-battery-life.html#ixzz1HLj9WRhr
Sms email does not sound notification
You will have to update your firmware and that should fix that problem. Go to blackberry.com and go to software update online.
make sure you give me a rating if this works out for you.
thanks
1helpful
Hi how can i increase volume on my blackberry 9000. Even on high volume setting there is no ringtone sometimes
Hi there
On your Blackberry menu, there's an icon that resembles a person's head that represents profiles. In the profiles menu, you can select the volume for the notifications you receive when messages or calls come in. Choose "Loud" to hear all notifications at an equal volume, equivalent to the maximum output possible.
Some ring tones just remain less audible than others even when they're set to maximum volume. If you've tried increasing the volume of your notifications but still can't hear the ringer sometimes, try downloading a custom ringtone from the Blackberry App Store.
When selecting a custom ringtone, choose something distinctive and hard to ignore. When previewing the tone, determine whether it seems louder or easier to hear than your existing tone. Download more than one tone and experiment throughout the day.
After you've downloaded custom ringtones, set your phone to use these ringers by going into the applicable notification profile. Select "Show Tunes" and open the media folder where you've chosen to save your downloaded tones. Select the ringer you want and click "Set as Phone Tune."
How do I change my SMS notification sound?
go to the media/sounds setting pick out file you like for sms. tap options save as sms notications........the same way you change ringtones
2answers
No sound Blackberry
Check your profile settings and make sure that it is not set to phone only or all alerts off. If it is set correctly double check your ringtones and make sure they are set for sound. If those options are there then do a battery pull. If it still doesn't work then I would do a search on the crackberry.com website. It is a great site for all things blackberry.
1helpful
My BB pearl 8100 doesn't ring for incoming calls/messages/emails, but if i go to listen my ringtones or music they all sound fine, i think it got corrupted or something because no matter how i change the...
Not sure if the pearl interface is the same as mine, a Storm - I have an option on my main screen to fast-select ring volume (called Notification), which affects both calls and messages, and I can choose loud, soft, vibrate, silent, and also go into options for more detailed settings. You may have such an option that is easy to find, and maybe easy to set by mistake, without realising it.
Pearl manual at this location:
http://docs.blackberry.com/en/smartphone_users/deliverables/1217/userguide_bb8100_gprs.pdf
see p193, Notification Profiles.
There are other keys, eg # that affect notification sounds/vibrate. Download and search in the manual for 'Notification" to find all the places mentioned.
Even if you have a paper manual, I recommend keeping the electronic one since you can easily search for keywords and find all the places they are mentioned quickly.
2helpful
Can't set my blackberry curve to ring and vibrate at same time
To silence your device
In the profile list, perform one of the following actions:
• To receive LED notification only, click Quiet.
• To receive vibrate notification only, click Vibrate.
• To turn off all notification, including notification profile exceptions and LED notification, click Off.
Hope this helps!
- CBR2009
Black screen on my storm
sorry buddy u have replace the screen from blackberry service outlets.
Regards
mohit
plz vote
Top Blackberry Cell Phones Experts
NOEL
NOEL
john h
Are you a Blackberry Cell Phone Expert? Answer questions, earn points and help others
