Cell Phones Logo
A
Anonymous Posted on Nov 29, 2019
Please help me with the my Samsung SGH-C300. It shows me "Phone locked. Contact the service provider." and I'm not have NCK and MCK codes MCK (phone freeze lock) NCK (network lock)
IMEI: 352240025606225 For MCK code: #0199*code# Locked to: Vodafone (Romania) For NCK code: #0111*code#
Not Me
Level 3:
  • Samsung Master 3,158 Answers
  • Posted on Nov 29, 2019
Not Me
Samsung Master
Level 3:
Answers
3158
Questions
0
Helped
163784
Points
31816
So contact Vodaphone for support, if it is your phone.
We can't help you
5 Related Answers
A
Anonymous
  • Posted on Feb 25, 2008
SOURCE: phone freeze unlock code
my samsung z500 hang after 1 min it turn on. keypad and other thing does not work.
Anonymous
  • Posted on Mar 02, 2008
UNLOCK MOTOROLA SYNC
DO NOT TRY MORE THAN TWICE ... u can only do 3 attempts .. if the third don't work u will freeze your phone
Unlocking the Sync Instructions
The idea is that you are changing your phone's 8-digit unlock code to all zero's.
(1)Turn off your phone and remove the sim card.
(2)Then power the phone back on.
(3)Enter the following numbers on the keypad: *2767*3855# this will restart your phone,
(4)When your phone has restarted and powered back on you will enter the following into the keypad *7465625*638*00000000*00000000# If your phone says wrong password, turn your phone off and put in an unaccepted Sim Card into the phone (A sim card from another Service Provider) and then start the process over again. If it says wrong password even with the wrong Sim card, then you have reached your second attempt, Do NOT try it again. Instead, go to Ebay and purchase an unlock code.
(5)NEXT ENTER #7465625*638*00000000#
(6)AND THEN *#7465625# to check the locks....all locks should now be inactive or Off
If you find that some of your locks are still turned on, now that you know your phone's unlock code, (00000000) you can use the following codes to unlock individual locks on your phone (Where you see the word Code you will put in your new unlock code, which is now 00000000:
#7465625*638*Code# = Disables Network lock
#7465625*782*Code# = Disables Subset lock
#7465625*77*Code# = Disables SP lock
#7465625*27*Code# = Disables CP lock
#7465625*746*Code# = Disables SIM lock
#7465625*228# = Activa lock OFF
Anonymous
  • 93 Answers
  • Posted on Mar 31, 2008
SOURCE: Samsung SGH-C300
you have to flash the phone i mean
try to enter zeros insted the numbers they gave u
if not so you have to take to a repair store to flash the phone
Anonymous
  • 271 Answers
  • Posted on May 22, 2008
Hi ,
you can download unlock client from below site
http://www.mobile2mobile.net/unlock/Remo... http://www.mobile2mobile.net/unlock/RemoteunlockingSamsung.htm?gclid=CLzQwIOBqYsCFQ-Wbgod2n3IjQ
PLEASE RATE ME...........................................
Anonymous
  • 4 Answers
  • Posted on Apr 25, 2009
FOR PEOPLE WITH PHONE FREEZE ON SAMSUNG- the #7465625*638*code# is not needed when you have the phone freeze just follow below.
I know how frustrating this was and i got it done by myself by experimenting since everything cant be googled that easily. i figured i can help anyone out. this has worked for 5 phones that i have done my self so 5 for 5 YESS!!! This is as satisfiying to me as watching micheal jordans final shot!
any ? contact me at [email protected]
ok i figured it out. for all those people that have gotten the dreaded phone freeze om samsung propel a767 or any other samsung phone so far not sure about touch screen.
first look for a local unlocker in ur area or somewher that can provide the codes and get the unlock code and phone freeze code. mine was only 20 for both and took less than 24 to retrieve. email me for his info.
insert sim that you want to use (tmobile). you get the screen which says phone freeze. type in the freeze unlock code which was given and the press the att logo/menu button.
**YOU WILL NOT BE ABLE TO SEE THE NUMBERS YOU ARE TYPING SO KEEP TRACK OF WHAT YOU INPUT**
after you have entered number and pressed button then you will get a network lock screen. this is where you type in ur unlock code. type that in press confirm and BAMM!!!! you are now able to use tmobile sim
Samsung sgh c300 unlock
To unlock Samsung SGH C300 use unlock code.I would suggest the site Simpleunlocking.com get unlock code and get free unlocking instructions from Mobileunlockguide.com and unlock it from service provider lock.
3helpful
2answers
It is locked in vodafone
Connect the original cable to the phone and PC. Go to an online unlock site and unlock it. It will cost $15:
http://www.unlocksamsungonline.nl/unlock-samsung-J600
There are also other free solutions but I would not trust them, since in some cases they do not work.
I attach one just for the record:
http://srimeenakshimobiles.com/forums/nspro/1241-easy-way-unlock-sgh-j600.html
I have samsung mobile model is c300 so when i put sim card then open it then it show the wrong card so please give me solutions for this problem..thanks in advanced..
To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use it with adifferent phone provider, Please click on this link and follow my instructions:- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB site also - UnlockFree http://www.unlock-free.com
3helpful
4answers
Need an unlock code for Samsung C300
You can get the unlock code here http://www.mobileunlocksolutions.com...-phone/rs1wp2/ and also get the unlock instruction in the same site....
2answers
5helpful
5answers
I WANT TO UNLOCK SAMSUNG MOBILE SGH C207...provided by Cingular (USA)....I want to use this handset in India mobile operator (Airtel), please provide me the unlock code.
Friend you can use this site http://www.mobileunlockguide.com/ .It provides the unlocking instructions for your mobile.After getting the unlocking code, you can use this site for unlocking procedure.
I need to my SGH-C300 password.
first enter the code 3 times wrong. den enter ur puk number and it will work for sure. the puk number came wit ur sim card pack. if u cant find t contact ur service provider and dey give it to u immediately. tks
2answers
Need unlocking code for samsung c300
hi,
THIS CODE WILL UNLOCK ALL OF THE NEW MODEL SAMSUNG PHONES EXCEPT SMART PHONES. (X495-AND UP)
NEXT ENTER
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
network lock - inactive
subset lock - inactive
sp lock - inactive
cp lock - inactive
sim lock - inactive
activa lock - inactive
phone lock - inactive
auto network - inactive
auto subset lock - inactive
auto sp lock - inactive
auto cp lock - inactive
auto sim lock - inactive
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; adsByGoogleRight = "5px"; document.getElementById("ga_300x250").style.width = "370px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //--> var niB = document.getElementById("niBannerID"); if(niB && niB.style.display=="block"){ document.getElementById("q_answer").style.marginTop = (niB.offsetHeight+30)+"px"; } -->
2answers
Please help me
I've explained the puk code on this page
basicly contact your service provider.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
