Hi Modupeola-
I found this link.
https://www.lg.com/ph/support/support-product/lg-32LD330
Download the owners manual. On page 33, it talks about VESA wall mounting specifications. The 22LD330 26/32LD330,32LD340, 26/32LD331C all use the LSW100B, LSW100BG wall mounting bracket.
Hope this helps.
SOURCE: Can I use any universal wall mount for my LG
Just check the weight and size restriction on the wall mount. As long as the weight and size specs of the TV fall within those allotted by the wall mount, you should be fine.
SOURCE: wall mounting the LG 42LC2D TV there are holes in
There will be 4 big holes used to install a mounting bracket on the back of the TV.
SOURCE: LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Testimonial: "Thank you! We'll head to Lowe's tomorrow to pick up the appropriate size screws. We just moved into a new home and they left the wall mount up for us, but did not leave any of the extra screws that went with the mount. Thanks again! "
SOURCE: new for verify mounting screw
Yes they are. They should be in a square and should line up to a bracket for your mounting hardware.
