Question about Mitsubishi Televison & Video
I have a Mitsubishi 1080 dlp tv and the green light is flashing and its making loud clicking noise what could be the problem thanks in advance
    Top Expert:
  • Mitsubishi Master
  • 55,370 Answers
Open internal fuse or power supply failure
Posted on Nov 30, 2019
6ya staff
SOURCE:
premtech
William Rayburn
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
Anonymous
SOURCE: flashing green light
I had the same problem due to power surge.Repairman came and said power board replacement might fix--$300 parts and labor, but if DM module is damaged, another $600-700. My set is 5 yrs. old. I'm shopping for a new LCD.
Posted on Jan 09, 2008
Anonymous
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Posted on Nov 29, 2008
Anonymous
  • 9 Answers
SOURCE: mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Posted on Mar 18, 2009
Anonymous
SOURCE: HEARD LOUD POP NOISE DLP TV DOES NOT WORK
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
Posted on Feb 11, 2010
TV (wd-82738) shuts down unexpectedly and fast flashing green light comes on This occurs about once a week.
The tv flashing green light is on it have a word"LAMP"writing on the tv frame?Yes,than the tv projection lamp life it is ending.Tv unexpectedly shutdown the tv also have clicking noises sound too?That the board call the Ballast board is dying too,this board only job are only to ignite the projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp and might have also have to replaced the Ballast board too.
Apr 13, 2011 | Mitsubishi WD-82738 DLP TV
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
I have a 6 yr old Mitsubishi DLP WD-52327 does not fire up... When power is turned on tv makes a noise like a small air compressor for a few seconds and then stops after about 1 minute it does it...
No.The tv have a colors wheel is dead.The colors wheel make loud motor noises,squiling noises and flashes picture with black&white.The colors wheel is dying and spinning off of it motor axis.Hire a Tv Tech. to change the colors wheel.Because is require take out alots machanical parts,before u can even come to the colors wheel itself to replced.
Oct 23, 2010 | Televison & Video
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Installed new bulb and now there is a loud whirring noise and multi colored flashing on screen
Sounds like the same problem I had, I bought a new bulb as well, installed it and nothing. I googled that same issue and endedup buying a kit herehttp://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits/osCsid/145ffde26a9336eaf57c21ff6389def7that came with capacitors that had to be replace, the kit comes with aservice manual and a bag with lots of different capacitors to replaceany out on your board, they are really good at troubleshooting and theyoffer help online. If that is whats wrong with you, you will need asoldering tool, I bought my as a kit at radio shack for $20.00 and plusthe $36.00 for the kit, and a lot of patience, my TV is well andrunning now, it was better than the $600.00 estimate I got from a localrepair shop. Good luck!
Sep 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
