Question about KitchenAid Refrigerators
I need exact measurements on a KitchenAid superba refrigerator model no. KSCS25FKSS02
  • KitchenAid Master
  • 6,065 Answers
Kitchenaid has a dimensions guide for the KSC25FKSS refrigerators on their support site: https://www.kitchenaid.com/service-and-support/manuals.html . The depth depends on the handle style; these models are 35 1/2" W X 27" or 27 1/2" D X 71 7/8" H. The link to the document is https://www.kitchenaid.com/content/dam/global/documents/200312/dimension-guide-2221514-D-KA.pdf .
I hope this helps.
Posted on Nov 29, 2019
6ya staff
SOURCE:
robert samples
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
Anonymous
  • 525 Answers
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Posted on Aug 13, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: how do you take out and change the water filter on
At the bottom of refrig , on the toe plate , press the button on the left kinda hard , and the filter should pop out .
Posted on Sep 24, 2009
Testimonial: "thanks for the help. "
Anonymous
  • 12 Answers
SOURCE: How do you replace the water filter on a
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Posted on Oct 19, 2009
dwastchak
  • 4 Answers
SOURCE: Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Posted on Jan 24, 2010
I need the dimensions for Kitchen Aid Refrigerator model # KSRS25IKSS01
http://www.dostami.ru/KITCHENAID-Superba-KSRS25IKSS01-25-cu-ft/ebay-item/120871216158/description
Jan 12, 2013 | KitchenAid Superba Architect KSCS25INSS...
What type if filter do I for kitchenaid superba ksrb25fhss01?
The refrigerator water filter for the kitchenaid superba ksrb25fhss01 is part number 4396508. If you order it from Sears Parts Direct, it's $45. See: http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSRB25FHSS01/0593/0165000/O2029608/00002 . It's available from other sources for less (including Amazon: http://www.amazon.com/Whirlpool-4396508-KitchenAid-Maytag-Refrigerator/dp/B0009793KC .)
I hope this helps.
Jun 24, 2012 | KitchenAid Refrigerators
Find a replacement for Kitchenaid KEMS376S ~ tricky dimensions
your local dealer shouold have available to them all the manufacture specs and which unit would fit your needs.
Mar 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freeze does not cool down. Model kscs25fkss02
two things to try. open fridge. at top you will see temp slider for the freezer. adjust towards cold and see if that helps.
or: is ice door on ice/water dispenser closed all the way? this fails to shut all the way, then warm air from the room gets into freezer. If this happens, call the repair guy.
Feb 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
How do you change filter in Kitchen Aid superba refridgerator
The superba series is a dishwasher type. the model number would be really helpfull. either way if you go to kitchenaid.com and click on product type then on refrigerator it shows all models and when you click on your model it takes you to its page and on the bottom of the page is the installation guide and every manual for your fridge. its all in PDF format and really easy to use. if you still need help please email me at phoenixnixinks@yahoo.com with the model number and i will be more than happy to help you farther.
good luck
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
May 13, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid Refrigerator Superba
heres a part number for the valve, somple enougth to install just turn off the water supply and installe ne wvalve, exact replacement. soundsas if its not closingt correctly allowing water to tricklel in part number 4389177
Apr 07, 2008 | Refrigerators
Model Number
Open the drawer or bottom cover panel and look on the facing where the door closes to
Dec 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
