Question about Boating
How do I separate a stuck lower unit on a 1984 25hp Evinrude?
I bought a boat with a 25hp Evinrude that appears to have not been maintained. I want to replace the water pump and maybe some other seals, but cannot get it to drop. I've squirted PB Blaster on the main bolt for weeks and still not budging. Hitting it with large rubber mallet is getting me nowhere. Saw a YouTube where the guy stood his motor upside down and pumped an entire can of degreaser into the housing to free up a stuck drive shaft spline. I also had a guy tell me that I needed to heat the bolt area really hot, but I only have a propane torch, no acetylene. Any ideas?
    Top Expert:
  • Boating Master
  • 66,184 Answers
IF IT DROPPED PERHAPS 1/2 INCH THE SHIFT ROD NEEDS DISCONNECTED .
Posted on Nov 30, 2019
  • nw_zfan Nov 30, 2019
    Thanks for the tip. It has only separated enough to maybe slip a razor blade in. This is only at the front (away from the main bolt). I did remove the small bolt from the shift rod coupler. It is a long shaft. Should I be trying to separate at the top the "extension" section, or just the lower part? i have removed all 8 bolts holding both sections together. It does seem that the main bolt with the nut on top has not moved at all. Still squirting a few drops of PB Blaster on the threads to soak down in any time I walk by the motor. Very frustrating.
2 Suggested Answers
6ya staff
SOURCE:
fordexpert
  • 5692 Answers
SOURCE: 1975 75 hp evinrude water in lower unit
You could take off the lower unit and leave the boat home. All they need is the bottom. The propshaft seal can be cut from fishing line. There should be another seal on the shift assembly and a third on the powershaft. Some you could do, but the shop can pressure test before and replace only what you need. Then pressure test after the repair to verify it seals.
Posted on Jul 20, 2009
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Jul 09, 2017 | Cars & Trucks
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
85 40hp evinrude stuck in forward?
Evinrude used a shift mechanism located in the lower unit that is actuated by a rod up to the linkage in the motor housing. It could be stuck anywhere along the way or the gear that shifts on the shaft could be immobile due to rust and corrosion.
You may want to find a blowup of your exact model via a Google search. Then starting from the top look for your problem. be sure to mark the position of anything adjustable so you can at least get it back to the original position when you reassemble it.
Find 1985 40hp Johnson Evinrude Outboard Motor Parts by Model Number
Feb 06, 2015 | Light Outboard Motor Boat Bass Fishing...
Evinrude troubleshooting
check lower unit oil if ok . pull prop off see if it has a wod of string around the input shaft behind prop sounds to me its in a bind
Nov 19, 2013 | Boating
Will a 1973 50 hp Evinrude OMC lower unit fit on a 1988 evinrude 50 hp
Tony, that's a problem for the boat motor repair section.
Nov 02, 2013 | Vacuums
Trying to get lower unit off a 88 25hp evinrude motor
www.youtube.com go there and type water pump replacement 25hp Johnson or evinrude. You can also go to
http://shop2.evinrude.com/Index.aspx?s1=gett3uheq5c0nce2mjg11d1eh0&catalog_id=0&siteid=1
Thank you, Lewis Hot Headz Marine
Sep 25, 2013 | Boating
How to release shift rod to lower unit on 1987 30hp
Are you wanting to disconnect the shift rod from the lower unit?? It just unscrews..
..getting it screwed back in and set to the CORRECT HEIGHT is EXTREMELY IMPORTANT..(if you want to be able to shift and make the lower unit to last!)
get one of these,, its invaluable!!!
Johnson Evinrude Manuals 1917 2007
Jul 08, 2012 | Boating
How to replace impeller on evinrude 115
disconnect the lower unit from the power head . makeing sure where the shift rod position is . then you will be getting near the water pump impeller .if you get it wrong the shifting won't work
Apr 24, 2010 | Boating
Jul 20, 2009 | Boating
Boating Logo
62 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
