Hi Ann-
I found this link for Brother SQ9185 regarding threading the self threader.
https://help.brother-usa.com/app/answers/list/st/5/kw/thread%20self%20threader/p/6518/page/1
How to use the automatic needle threader
Follow these steps to use the needle threader: 1. Thread the machine up to the needle. CAUTION The needle threader can only be used with home sewing machine needles size 75/11- 100/16. Check...
Hope this helps.
I also found this youtube video on threading a self threading machine. Highlight the link, right-click and "Go to https://video.search.yahoo.com/..."
https://video.search.yahoo.com/search/video;_ylt=AwrDQymj7u9dlzEABwz7w8QF;_ylu=X3oDMTBncGdyMzQ0BHNlYwNzZWFyY2gEdnRpZAM-;_ylc=X1MDOTY3ODEzMDcEX3IDMgRhY3RuA2NsawRjc3JjcHZpZAMuMWZiTVRFd0xqRXlpaEVKWGFfVmpnQS5NVGd4TGdBQUFBQlRGZ1cxBGZyA3lmcC10LXMEZnIyA3NhLWdwBGdwcmlkA1N0MlFsVHlFU1RPYm1nQVFkWFJrWUEEbl9yc2x0AzYwBG5fc3VnZwMxMARvcmlnaW4DdmlkZW8uc2VhcmNoLnlhaG9vLmNvbQRwb3MDNQRwcXN0cgNicm90aGVyJTIwc3ElMjBzZXdpbmclMjBtYWNoaW5lBHBxc3RybAMyNQRxc3RybAM2NQRxdWVyeQNob3clMjBkbyUyMGklMjB0aHJlYWQlMjB0aGUlMjBicm90aGVyJTIwc3E5MTg1JTIwc2V3aW5nJTIwbWFjaGluZQR0X3N0bXADMTU3NjAwNTQ3Mw--?p=how+do+i+thread+the+brother+sq9185+sewing+machine&ei=UTF-8&fr2=p%3As%2Cv%3Av%2Cm%3Asa&fr=yfp-t-s#id=9&vid=64b3d386b183082abaa9d1d63e50e21e&action=view
Hope this helps.
SOURCE: how to use automatic threader on the pe180d embroidery machine
make sure needle is in the highest position before you thread
mary h
SOURCE: Broken needle threader?
Hi - welcome to FixYa. I have this machine, and unfortunately, the cassettes can break. If the threader worked when you first got your machine, I would suggest buying a new cassette (even if your threader is working). A second cassette is very handy because you can thread your next color in the extra cassette before the machine stops for the next color change - when the machine does stop, just put in the second cassette, and thread the other with the next color - speeds things up alot. And, if one of the cassettes does break, you aren't sitting in a puddle waiting for a new one.. You can find the thread cassettes for sale on a variety of sites - this is where I buy mine:
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Store_id=492&page_id=17
Some of the 270Ds came with a spool pin - look in your manual for a picture and for the instructions for installing and using the spool pin. You can use it for spool of thread that are too large for the cassette and I think you can leave it installed on your machine all the time. If you don't have your manual, leave a comment and I'll look mine and check the instructions.
Hope this helps. If you have a minute, a rating (good or bad) tells me if the information or solution I provide is helpful to anyone who visits FixYa.
If you would like me to write a tip on salvaging an embroidery project that has been pulled into a birdsnest, leave a quick comment and I'll add the tip. Thanks everybody, and good luck. Please feel free to comment if you need more help or have more questions.
SOURCE: When I try to thread my needle, the arm doesn't
Refer to your manual to be sure you have the needle in correctly.
SOURCE: brother pe770 - needle threader is stuck in the
Hi Kay,
I found the manual, in case you don't have one, HERE. On page 30, it has an illustration showing two buttons, and the presser foot lever. If you press the button once or twice, it will raise the needle.
> Press (Needle position button) once or
twice to raise the needle.
> The needle is correctly raised when the mark on
the handwheel is at the top, as shown below.
Check the handwheel and, if this mark is not at
this position, press (Needle position button)
until it is.
Get the manual if you don't have one, that will give you so much more than any here can do, but I think that should solve you trouble, Please rate and comment, Thank You,
Joe
