Question about GPS
MY ETREX GPS SHOWS THE WRONG YEAR.HOW DO I CHANGE THE YEAR
    Top Expert:
  • GPS Master
  • 30,539 Answers
eTrex H Time and Date are Incorrect ' Support Center
https://support.garmin.com > en-CA
Garmin has identified an issue with eTrex H GPS firmware that causes the time and date to be incorrect. A software update is available that resolves this concern ...
Wrong date on Etrex H ' GPS Forums
https://www.gps-forums.com > GPS Forums > Garmin GPS
Dec 26, 2018 - 12 posts - ‎4 authors
Where the date of the unit would jump back some 20 years because ... My Etrex H, having worked perfectly for many years, suddenly shows a ... Garmin GPS 12 wrong date
Jan. 23, 2017
Etrex Vista Hcx rollover problem
Apr. 30, 2019
wrong date on Garmin 12 GPS
May 25, 2006
GPS 12 wrong date Garmin
Posted on Nov 28, 2019
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 64 Answers
SOURCE: garmin etrex GPS
If it is posible to, which it should be, go to menu, then setup, then units. Use the position frmt field, your best bet. Hope this helps!
Posted on Jul 26, 2007
Chuck Badeaux
  • 95 Answers
SOURCE: Please I need GARMIM GPS ETREX VISTA USER MANUAL
Here's a link to the free pdf file. Just download and print it out.
http://www.gps.caltech.edu/gislab/equipment/eTrexVista_OwnersManual.pdf
Glad I could help
Posted on Mar 28, 2009
TO Lady
  • 638 Answers
SOURCE: Garmin eTrex HC GPS Location settings set to TL
Owner's manual Page 42
Setup > Units > Position Format
Please come back and tell us if this fixed your problem, and rate our solution. Thanks.
Posted on Jan 04, 2010
Testimonial: "Thank you so much. I looked and looked through the manual and had actually played with that particular setting but didn't realise it. Thank you."
My 3 year old Garmin Etrex Vista just started displaying horizontal lines across the entire display. Any suggestions?
Try updating the unit's software via the Garmin.com website. This may fix it as there was a satellite launched which was causing problems with some Garmin units.
Sep 25, 2009 | Garmin eTrex Vista GPS Receiver
Etrex will not power up
Hmm... Something is wrong contact the manufacture
May 04, 2009 | Garmin eTrex Vista GPS Receiver
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
Garmin Etrex - ORdnance Survey Grid reference nos
You shouldn't have to connect to a computer. I don't have an OS map in front of me but I'm guessing they use UTM with a WGS 84 datum (if the map was produced after 1984 that is). Got to the Setup page then select Units. Change Position Frmt to UTM/UPS and Map Datum to WGS 84.
Jul 29, 2008 | Garmin eTrex GPS Receiver
Elevation Problem
Some models have the Barometric Altimeter which needs to be calibrated, and some units do not.
Vertical Accuracy of a properly calibrated Barometric Altimeter is +/- 10'. If you have a unit that uses provides a GPS Elevation only, a +/- 50' vertical solution is pretty standard.
Jun 22, 2008 | Garmin eTrex GPS Receiver
GPS displays BNG on location
BNG stands for 'British National Grid'
  1. Go to the Setup menu
  2. Select Units
  3. Change the Position Format to hddd°mm.mmm'
Jun 14, 2008 | Garmin eTrex GPS Receiver
Garmin etrex
This is a problem with the garmen, however, sometimes if you can remove the battery, and leave it out for one hour, then replace it while facing north outside, it usually re adjusts itself. also sometimes if you can reset the unit that will also sometimes bring it around. if that doesn't do it, I suggest contacting garman tech support, it may have to be sent in to have the software updated or it can be a defective unit, if it has been dropped., or gotten wet.
Jun 07, 2008 | Garmin eTrex GPS Receiver
Garmin Etrex Vista
change the software or update the software of ur gps
Apr 22, 2008 | Garmin eTrex Vista GPS Receiver
No location shows
  2. Select Units
Aug 19, 2007 | Garmin eTrex GPS Receiver
GPS Logo
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
