Navigate to appleid.apple.com in your browser. Sign in with your Apple ID and password. Click Edit in the Account section. Select Change Apple ID under your current email address.
How to Create, Change, And Remove Apple ID On Mac
SOURCE: yahoo mail on an apple mac
Assuming you have chosen the correct server from the list on the bottom of your outgoing message you need to set up both the incoming and out going servers, you should be able to get the details from your account information page then open mail and in the title bar click on MAIL and a drop down menu will appear and select preferences and a new window appears, select accounts and you will see, under account information 3 sections the top is likely filled in being the account type,the second should be there too, the third is the outgoing server, this could be missing or wrong
SOURCE: how do you reset your apple account s oyou can put your apple id in the ihpone and not someone elses
All Apple devices have what is called an activation lock. If the incorrect Apple ID was still logged in when you did the factory reset, it will prompt you to log into that Apple ID before you can proceed through setup. Once you have done so, you can log out of the incorrect Apple ID and into the correct one.
This is a security feature that Apple has written into their software to deter theft of iPhones.
