Question about GPS
On startup my BekP5LMU (Becker)display the message " no gps ". What's hapen and how I can reset it to a normal function ?
98 Oldsmobile Aurora There's a on my Dash it says information center and has the oil fuel speed all that it says low oil is there any way anybody knows how to reset that
Check your engine oil using the oil dipstick located on the engine - you need to add oil to the fill line as shown on the dipstick. You should have the oil replaced regularly (every 3-6 months) and keep your eye on the level if the engine is leaking oil underneath or burning a lot of it.
Mar 08, 2017 | Oldsmobile Cars & Trucks
How to insert a car radio code on a Becker radio in a Vito van that only has rotating dials and no pre-sets
If you are trying to fit this radio to a different vehicle, then you may find yourself with the Error message of "PROD". This stereo is electronically paired, or "Married" to the engine management system of the vehicle it came out of using very sophisticated CAN-BUS system technology.
When it is first powered up, it will communicate with the vehicle, and whilst this process is in operation the set will appear to function correctly, and if communication has been successfull, it will continue to operate in the normal way.
However, if removed and refitted into a different vehicle other than the original one, it will not recognise the encrypted CANBUS identification of the new car, and will instead display an error message of "PROD" after around 30 seconds.
This Radio cannot therefore be transferred from one car to another, unless it has first been reset back into its original "Delivery Mode" with the internal CAN-BUS data memory reprogrammed for use with the new vehicle.
and yes that code for that serial but i dont think your need that
Jan 01, 2015 | Becker Car Audio & Video
Becker radio displays WAIT
to get it working again when the "WAIT" comes on it may take 10/15 minutes before the "WAIT" to go off and then i turned the volume control to the first code number, then push am/fm button to lock it in. repeat until all the code numbers are in and the radio will start normal operation. There is a code number card that comes with the radio, if you do not have it, go to the mb dealer with your vin number and they will give you the code number.
Jul 22, 2014 | OEM 1993 Mercedes 300D Radio / CD Player...
Battery becker 7827
Assuming you have or are able to extract the old battery, find the model number of the battery and google it. Odds are you'll get multiple replacement options.
Apr 28, 2013 | Becker Traffic Assist 7827 Personal...
I cant turn on oregon 450
I just resolved this issue on mine. By holding down the power button when hooked to the computer via the USB cable, I was able to "force" the GPS into mass storage mode. I went to "my computer" icon and clicked on the Oregon 450 to be able to view it's hard drive contents. Open it up, delete all .gpx files for the .gpx folder. I then went to Garmin.com and downloaded/ reinstalled the current software for the gps. All this allowed me to perform the "Master Reset" function and restore the Oregon 450 to it's original functioning. Mater reset is described as follows: touch the upper left corner of the display screen and continue to hold the touch while depressing the power button. As the GPS powers up, continue to hold the touch in the upper left corner until the message screen displays : do you want to reset, press yes then it is complete. Worked for me...maybe you too!
Feb 09, 2013 | Garmin Gps outdoor Oregon 450
Want to update my becker gps
Did you ever get an answer to this problem? I'm having the same problem
Jul 29, 2010 | Becker Traffic Assist 7914 Car GPS...
Have presario 6000. Would not boot but received message that new keyboard needed. Purchased "universal" aftermarket keyboard. New message "Hard drive failure imminent" and still would not boot to allow...
Prepare to Diagnose the Computer
Perform the following actions to prepare the computer for troubleshooting a startup problem.
1. Remove the battery and AC adapter from the notebook.
2.Remove any optical disks (CD or DVD), and disconnect any external devices or peripherals such as USB devices, printers, docking stations etc.
3.Plug the AC adapter directly into a functioning wall socket.
4.Press the Power button to turn on the computer.
NOTE:After the battery, optical media and peripherals are removed, the Notebook PC may startup normally. If this occurs see Windows starts after the battery, optical media and peripherals are removed .
Symptoms and Resolutions
When the notebook stops responding or displays an error message, let me know what symptom that most closely resembles what is seen on the Notebook PC screen.
* Screen is blank with no cursor or text
*An error message is displayed on a black background
*An error message is displayed on a blue background
*PC stops responding on a red Compaq or blue HP logo screen
*PC Stops responding on the Windows logo screen
* The Microsoft Windows 'Advanced Options Menu' is displayed
* PC stops responding with a blinking cursor is displayed in the upper left corner of a black screen.
*Password is requested but password is forgotten or lost.
*Microsoft Windows starts, but a 'serious error' message is displayed that prompts you to send an error report to Microsoft for evaluation.
* Microsoft Windows starts , but the PC stops responding or restarts automatically
*Display is very dim during and after startup
*Microsoft Windows starts, but runs abnormally slow
Jan 28, 2010 | HP Pavilion dv9000z Notebook
How to reset gps
There's a small pin hole somewhere on the unit were an ink pen tip can fit in. Inert the tip of the pen in the hole and hold it for about 3 seconds and release it. This will reset the unit. I have a Becker GPS.
Dec 06, 2009 | Lowrance Iway 500c GPS Receiver
GPS Logo
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
