The Ultimate Energizer Guide Overview:Could It Be a gimmick or genuine ? genuine reality exposed? The Ultimate Energizer Guide By Steven Perkins
SOURCE: Xerox Work Centre C2424 System Error
Hi there
I found some thing maybe do for you it may not be rhe right code you have at this moment but it come in handy for you.
31,004.40:6909: it's a mechanical initialization jam error. Pull out the paper tray to make sure it doesn't have a jam. Try also to manually feed some heavy paper or card stock through the printer to make sure the sensor in the preheater isn't stuck.
39,002.40 : DRAM test failure.
39,012.40:56208: "Cycle the power" and if that does not work replace the document feeder.
39,012.41: Document Feeder Optical Failure. Replace the document feeder.
4,0XX.6x: Process Control Software Fault.
· Reset NVRAM and then retest.
· Ensure ground integrity for the system
· Replace the EEPROM chip.
· Reboot the system.
· From the System Setup menu, go to "Information", "Troubleshooting"
· Service Tools menu.
· With the cursor at the top of the Service Tools menu, press both the Up Arrow
· and Down Arrow buttons to display the Hidden Service menu.
· Reset NVRAM is in there.
Also may be handy is this.
4,0XX.6x Process Control Software Fault
Error 04,041.66
Solution 1:
a. Reset NVRAM and then retest.
b. Ensure ground integrity for the system.
c. Replace the EEPROM chip.
d. Reboot the system.
1. From the System Setup menu, go to Information --> Troubleshooting -->
Service Tools menu.
2. With the cursor at the top of the Service Tools menu, press both the Up Arrow and Down Arrow buttons to display the Hidden Service menu.
3. Reset NVRAM is in there
Solution 2:
1. Turn the system power ON.
2. Wait for the Xerox logo to begin moving across the display.
3. Before the logo is centered on the display, press and hold the Back and Info buttons on the control panel.
4. Hold both buttons until the display reads “Beginning Service Mode Initialization”. Release the buttons and the system reboots into service mode with the Service Diagnostics menu displayed.
Hope it will help you in some way of finding the fault.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: our xerox workcenter 7235 fault
024 360 An error has been detected by the Controller during communications with the Printer. User
intervention is required to Power Off/Power On the machine, Field Service is required if the
problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
