Hi Junior-
I found this youtube video on resetting f10 code on a gas stove.
https://www.youtube.com/watch?v=z6tcnpDKDns
Hope this helps.
SOURCE: Frigidaire Stove model # 791FEFS66DS
F10 is a Runaway temperature issue.
There are three possible scenarios:
1. The temperature sensor has failed.
2. The electronic control has failed
OR
3. The connector between the temperature sensor and the electronic control has failed.
The connector can be troublesome. The first thing to do is eliminate this potential issue.
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
SOURCE: f10 code
replace the oven probe in the oven its the gold looking piece sticking out inside the oven
SOURCE: What does F10 display on my stove mean? Frigidaire Model PGF355DS
my frigidaire oven keeps flashing f10 and turning off
SOURCE: How do i fix f10
Here is the main Frigidaire ONLINE SUPPORT page for the closest model of wall oven I could find to yours (FFET2725LS), hopefully the controls and instructions will be similar enough:
http://www.frigidaire.com/products/kitchen/wall-ovens/ffet2725ls
And here is a direct link to the ONLINE USER"S MANUAL for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205315en.pdf
To view the Owner's Manual / Operating Instructions just use your mouse to click on the link which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information in the operating manual.
You may need ADOBE READER on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the page when you get there.
The F-10 code most likely indicates an electrical fault with the oven temperature sensor.
See the following link for information on Oven Temp Sensor faults and testing instructions:
http://www.applianceaid.com/oven_temp_sensors_help.html
You can try to remove the temperature sensor and clean the electrical contacts in the connector to remove any rust or accumulations on there and then reconnect it and try the oven again.
See the following link for all F-Codes faults and repair actions.
http://www.applianceaid.com/faultcodes3.html
Please comment back here to this page if you have questions or require further assistance.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon on this page.
Thank you very much.
Joe
www.ask.com/mfg.name/make/model/error/code/F10/
Hello friend, thanks for the post!
I understand your Frigidaire wall oven is flashing a F10 code and not heating up. Based off of that information an F10 code stands for a runaway temperature, which could be an issue with a sensor probe or oven control. It could possibly be a miscommunication with the board and that could be cleared out by resetting your appliance. To reset your appliance disconnect power to it by unplugging the oven or flipping the household circuit breaker for ten minutes. If that step does not resolve your issue and you continue to receive the F10 code I would recommend contacting a technician to come and repair your appliance. I hope this information is helpful. -Matt
Hello Carol Martin - Typically, error codes F10 and F13 could indicate a variety of issues. The range could possibly have a shorted keypad, runaway temperature (higher than normal temperature), faulty EOC (electronic oven control) or, display wire harness missing/not connected. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
