SOURCE: I have a kitchen aid upright and am trying to
is there 2 compressors on the unit? if only one you may have a gas leak!
SOURCE: I just installed a Wood 59018 timer, and when i
Timer is wired wrong and timer white and timer red wires are probably connected together.
Timer white wire has to be connected to white neutral wires that are twisted together and shoved to back of box. This will power the clock mechanism inside timer.
If box does not have white neutrals, then connect timer white wire to bare ground wire along with timer green wire.
Timer black wire connects to Hot wire.
Timer red wire connects to Load wire.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
SOURCE: sound doesn't work tried settings
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
SOURCE: The day date always now
Hi!
The problem you described is caused by incorrect setting of the hour: AM and PM must be set correctly, AM before noon and PM afternoon.
For more details regarding setting of your watch, please visit Citizen site here:
http://www.citizenwatch.com/COA/English/settings.asp
Please let me know if it helped,
good luck!
SOURCE: I have a 2003 alero that keeps having starting
if fuel pump is working, and the pressure is ok! then check for a faulty Ignition switch,not the ignition lock and key, but the switch itself.
These are notorious for this and have the exact same symptoms. if fuel pump does not work, check relay in fuse box. hope this helps you! check the pump relay first. just swap the relay from another spot to see if this helps.
good-day! if all fails, go to store and buy a can of compressed air in a can and put staw in ignition and spray it good a few times this may help because on these cars they get dust in ignition, and it messes up the contacts. the same as you would use for cleaning keyboard dust- you can buy it at Best
Buy, hardware stores etc)
- place the thin extension "straw"
(that comes attached to the can) on the nozzle
- blow out
the key hole (use at least half a can of the compressed air)
- soak the key in rubbing alcohol for few minutes
-dry the key.
