Https://myview.com.ph/deluxe-series/50u10/
Contact them for an instruction manual?
Sometimes your Settings has Audio settings to choose between Internal Speakers or Digital or Analog outputs. Have you checked the Settings menus thoroughly?
Also check for Mute and for Volume.
If it is new, you can also contact your seller for support under warranty
This is the fifth time you have asked in 10 minutes, *Please* do not post the same question repeatedly.
SOURCE: Program bell expressvu remote for new tv
The easiest way is to do device code scan. Since you want to program the TV, hold the TV button on your bell expressvu remote. When all the top buttons light up, press the power button, the TV button light should remain lit. Keep pressing up/down until your TV turns off. When your TV turns off, press the # button. Thats all. Your done.
If you want to set up the AUX button, hold the AUX button until all the buttons light up. Then press * and either
0 - second TV
1 - second VCR/DVD player
2 - audio amplifier or cable box
Then press the power button and press up/down until the device turns off. The last step is to press # and your done.
SOURCE: My proscan 32LB30QD new tv does not have sound
the fuse to the audio compartment might be blown
SOURCE: Bought TV from a friend who had it hooked up to a
May I get the make and model # to help you more.
Now if this is your Tv that you have it listed under then go to link below page 8 and 9. You do not have speakers in the Tv you need to hook up external speakers.
http://www.hdtvsolutions.com/pdf/PDP504CMX-434CMXman.pdf
