Hi Stephane-
I found this link and youtube video regarding fixing an f10 error code on your range.
https://www.searspartsdirect.com/diy/article/troubleshooting-an-f10-error-code-on-a-range-video
hope this helps.
SOURCE: I have a run away temp on my fridgeair range oven
Might be the Eoc but most likely its the thermostat / thermal couple!
SOURCE: Error: F 10
That model number does not seem correct but error code F10 on the Electrolux ovens relates to a faulty power board.If that Serial is correct then it is still covered in the 12 months full warranty.
Hope that helps.
SOURCE: Kenmore Elec Range "Fire"...code f10
The F10 indicates that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: KENMORE ELECTRIC RANGE MODEL NUMBER 790.9621340C
The F10 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F10 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
SOURCE: oven elements will not shut off at set temperature.error code F10 appears
If you already tried disconnecting power to the oven for 20-30 minutes- and upon reconnecting it, get the same error code; then...
Either the electronic oven control board has gone bad or the oven temperature sensor has gone bad. There is also the possibility that the wires from the control board to the sensor has malfunctioned.
To start the troubleshooting process:
1.) Disconnect power to the oven
a.) Either by unplugging the stove from the electrical outlet OR
b.) Turning off the breaker (or removing the fuse) at the service panel
2.) Test the temperature sensor's resistance with an Ohm meter.
a.) This part is usually located on the back wall in the upper part of the oven cavity but it can be easy tested from the EOC.
b.) Locate the two pins in the plug at the EOC that are connected to the sensor. Measure the resistance between the wires connected to these pins. The normal reading at the room temperature is supposed to be about 1100 Ohms.
c.) If the reading is incorrect, remove the sensor from the oven and check its resistance at the sensor. If the reading at the sensor is the same as reading at the EOC plug, the sensor is defective.
d.) If the reading at the sensor is correct, the wire harness between the sensor and the control board is defective.
3.) If all of the above resistance values are in range, the electronic oven control board would need to be replaced.
Hello - Typically error code F10 indicates a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, these codes mean to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
