SOURCE: MY KEROSENE HEATER STARTS, RUNS MAYBE 5 MINUTES THEN SHUTS OFF
Same problem I had and it was the CAD/flmae sensor. you can get one that will fit from Mr. Heater for 3 bucks or from reddypats.com for 18. the wires are a different color but all you do is clip them and splice them to your old wire harness. It does''nt matter how you hook them as there is no hot and ground just a complete circuit.
SOURCE: Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
SOURCE: kerosene heaters run for 30 mins then shuts off.
Sounds like the pump or air filter is dirty. If cleaning them doesn't help, the pump will need to be rebuilt.
SOURCE: when filled with kerosene then plugged in, the
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
SOURCE: I have a Reddy Pro 115 BTU kerosene heater the fan
When you say that the fan starts then stops I assume you also mean that the burner starts and stops. If this is correct and the unit is more than a couple of years old you probably need to change the filter in the back and set the pump pressure. Both the filters and the gauges to set the pressure can be found at www.reddyheat.com along with a good explanation as to why you need the gauges. The pressure is set by bleed air pressure and must be exactly 3.5 psig. The gauge is the only accurate way to do it. The filters clog and change the pressure. When the difference is enough the unit will not run. Now with that said there are several other things which you should check. Check the fuel tank for water. Remove any you find. Remove the cover on the right side as you look at the unit from the front and remove the circuit board. Check for cracked connections. If you find any resolder them and reattach the board. That should take care of the unit and get you back to making heat. Let me know if you need anything else.
hardrocko
Thanks for using FixYa
Here are a couple of tips that I
wrote that tell you how to troubleshoot a Torpedo or Reddy
heater...
Reddy
Heater - Troubleshooting Torpedo Heaters
Torpedo
Heater Pump Pressure Adjustment
heatman101
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
heatman101
