We had a power flicker. Now the clock and oven work fine, but the stove top touchpad is not responding, so I can't turn on the burners.
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
SOURCE: LG Electric Range Oven touchpad buttons not working
The lock and unlock works well for the 4 - 5 button problem. However the "start" button failure is another problem altogether. I had this problem and found that the ribbon connector attaching the membrane switches to the circuit card (PWB) is where the problem lies. The ribbon cables (two of them) are connected by a pressure contact connector mounted on the PWB. This connection method is less than robust. the fix is to pull the ribbon from the connector, clean it carefully with a paper towel and some alcohol, and reconnect it. To remove the cable the connector has a small flange that pops up about .05 inch whn you pull on the connector. Once it pops up gently pull the ribbon cable out of the connector. To replace it just push the ribbon back into the slot on the top of the connector and snap the flange back down. I strongly suspect this connector will get dirty again every couple years as the oven vent fumes are not properly prevented from partially passing over the PWB right where these connectors are mounted.
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
