Hi Elsie-
If you do not have the remote, you can change inputs by doing the following:
Changing inputs
Inputs are selected by using a number of methods, depending on the model of your Sylvania TV. Switching inputs is usually accomplished by pressing the "Input Select" button on the remote. Each press will simply cycle through each available input on your TV. If no remote is available, the front panel has a button that matches the function on the remote. This button is located on the bottom-right side of the TV and doubles as the "Enter" button when accessing onscreen menus.
Hope this helps.
SOURCE: Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
SOURCE: how can i switch my
kindly check the remote settings and your manual for it. Select Menu and click Settings, then sort it out until you see the option Wide so that you can select it to widen your screen..
