Washing Machines Logo
L
Lisa M Posted on Nov 26, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My (10-year-old) LG front loader washer sort of "skips" when it spins to the left, like it can't quite catch whatever part helps it turn. Spinning to the right is fine.
Also was really loud when spinning to the left, and there was a burnt rubber smell.
robert
Level 3:
  • LG Master 2,548 Answers
  • Posted on Nov 27, 2019
robert
LG Master
Level 3:
Answers
2548
Questions
0
Helped
870488
Points
8043
My be a broken spyder. The part that holds the inner tub to the hub. Try wiggling the inner tub and see if it's loose inside the outer tub.
5 Related Answers
Anonymous
  • Posted on Sep 24, 2008
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 09, 2008
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Anonymous
  • 225 Answers
  • Posted on May 02, 2009
SOURCE: Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
JULIANFIX
ALBERT GARCIA
  • 975 Answers
  • Posted on May 18, 2009
SOURCE: Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
Anonymous
  • Posted on Apr 06, 2010
SOURCE: LG WD-8050FH LOUD noice when spinning & 'funny' burning smell!!
I had the same symptoms and almost dismantled the whole machine to locate the root of the cause. The issue was one of the 3 arms of the spider (like a 3 spoked wheel that connects to the rear of the drum and holds it in place and provides the drive shaft to through to the motor at the rear), had snapped after weakening from corrosion due to undissolved washing powder building up in the grooves.
To prevent this, do a hot wash every few weeks to dissolve the powder, don't think your saving the environment by using only cold washes, this should be in every washing machine manual to save the environment from waste from un-economically repairable appliances.
The burning smell was the unbalanced drum leaning heavily on the rubber shroud on the front between the drum and the outer casing. The replacement spider part was only about AU$60-80.
To check if this is the problem you may be able to tell by opening the door, and reaching in from the front with your palm up about a hand distance till you go past the rubber shroud and just touch the stainless steel drum. Grip it gently with your four fingers and pull towards the front (to you) about 1cm or two, with about as much force you would need to open the machine's door. Rotate the drum approx one third of a rotation and repeat, do this 3 times and you should feel one point give more than the others.
If no luck try again in sixths of a rotation, you can gauge the distance by the 3 plastic agitators attached on the inside wall of the drum.
Note: get a price on labour first to replace the spider, as this will be probably more than half way to a new machine, and then the cost of the part, and the call-out fee if you can't get it into a service centre.
What's the point of having a long lasting stainless steel drum when the key part that connects the drum to the motor is a weak cast iron / alloy part.
Ask your local service person what units have quality parts before buying a new machine.
ps: the loud noise is probably the cracked arm rubbing or the unbalanced drum hitting the sides and making the machine jump.
Hope this all helps!
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
2answers
My washing machine will not spin...
As you don't give the model, I can just give a generic reply.
Most front loaders are belt driven, and some top loaders are.
I think the main thing to look at first is the connection of the drive motor to the tub. If this is a belt - replace it and check the tensioner.
If it is a top loader using a gearbox, then the motor is likely to need either brushes or a new capacitor. Both items should be checked - so -
Belt ok? - Y= go to next question / N = Replace belt
Brushes ok Y= go to next question / N =Replace
Replace Motor Run Capacitor.
Startede spinning very loudly, possible bearing bad when spinning?
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it. If I have helped you, please rate my advice on fixya.
3helpful
Washer noisy in spin cycle
It sounds like your drum bearings are about to go. I am not familiar with this model, but I would assume it is pretty much like all other front-loaders. Bearing kits can be purchased for all models but there is a great variance in cost eg. in europe €25-€75. It is also quite a difficult job to undertake for the sunday diy enthusiast as it involves stripping down the machine and removing the drum. If you are going to repair the machine as opposed to replacing it I would strongly advise doing it asap and continued use will cause the bearings to collapse rendering the machine irrepairable. Hope this helps.
Lg front loader
check the pump to make sure its clear ,,,,, the front of the pump if i remember right turns to open
LG front loading washer (3 years old?) not spinning
Open the access door at the lower left front of the machine. Use the small hose to drain the remaining water from the machine. Remove the filter (the big knob thingy next to that little drain hose) and clean it out. Washer will not spin if there is still water in the tub. If there is nothing in the filter, you may have a pump motor / impeller problem. Do an "ask me" if need more help.
6helpful
3answers
Drum makes loud noise when spinning
3answers
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Washer doesn't spin
Try to replace the capacitor and let me know with your results. Good luck!
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
