I have a MP C305spf all in one printer that is throwing an error code of SC396-00. I have checked for paper jams and I am finding no jams. Need some assistance on this error. Thank you
The error code Sc396-05 on Ricoh copier indicates CMY Drum motor (Cyan, Magenta, Yellow) lock error. That means...
https://fixing-tech.com/solve-error-sc396-05-ricoh-mpc/
SOURCE: HP Officejet 6210 Printer; Paper Jam
Best Solution take off the small panel on the left side of the printer there you can see the white gears and one has a clear piece with black letters or dots on it with the panel removed look at the clear piece and try to start your printer if it does not rotate with the gear that is your problem. It is what tells the printer if the gears are moving or not. If that's the problem you have to take the printer almost all the way apart to be able to fix it.
SOURCE: CX11NF "Paper Jam" and Noise
Had the same problem, too. The grinding noise came from the gear of the loading mechanism, located (if looked on printer from behind) on the right side next to paper tray.
I had a problem with the paper loading, too.
That problem was due to a broken wire for the magnetic release of the loading mechanism, located on the right side, too.
My experience with this epson is, that most problems with it come from broken wires, e.g. the problems with the ADF I had, the problem with the magnetic release I had.....
If I hadn´t invested so much time and money in this printer, I´d rather scrap it immediately.
SOURCE: Message Paper Jam MP E
The sensor at the back of the printer is either stuk or out of position open the back of the printer and see if there is a little black lever sticking out if so check it for movement if it sticks yuo have to remove the back paper guide and reseat the lever in its correct position
SOURCE: CLP-500N Paper Tray error
It wants you to put paper in the multi-purpose or pull down tray 1 assembly.
