No sound with an audio CD or DVD or auxiliary sound input on my Phillips hts3450/37
6ya staff
SOURCE:
mixmaster
Timothy D
  • 626 Answers
SOURCE: switching on the auxiliary input
According to the manual, the AUX input is an optional accessory.
Check to see if the RCA jacks are labeled. I believe they are pre-outs only.
Best of Luck.
Posted on Nov 12, 2007
Anonymous
  • 1010 Answers
SOURCE: auxiliary audio input jack
No, you dont have one.
Posted on Jun 26, 2008
Anonymous
  • 87 Answers
SOURCE: Auxiliary Audio Cable
It is the AI net plug on the back of the radio, radio must be uninstalled. Just mathch up and go!
Hope this helps
Posted on Jun 03, 2009
wyno62
wayne
  • 364 Answers
SOURCE: is sony cdx gt24 has an ability to connect
From memory I believe you can, it should have the 2 connecting jacks and speaker jacks in the back, let me know how you go. Good luck
Posted on Nov 20, 2009
partyd
Ernesto Ruesta
  • 141 Answers
SOURCE: Auxiliary audio input for 2008 Mazda MX-5 with Bose sound system
Yes you can add auxiliary or ipod interface also xm radio
go here for more information
http://www.oemautosound.com/c-161-mazda-products.aspx
Posted on Apr 01, 2010
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
Cant figure out how to hook up the receiver to my phillips hi def tv and get the sound?
its old model, will not pass hd video, good only for audio. Connections depend on your equipment. If you use a cable box to watch tv, connect cable box audio out rca connectors (red and white), by an audio rca cable, to audio TV input on the back of the receiver. Now when you swith your receiver to TV input you get sound from cable box trough your speakers.
If you use DVD player: connect audio out of the player to dvd audio input of the receiver. Switch the receiver to DVD input, you have sound from DVD.
Jan 08, 2011 | Denon AVR-1403 Receiver
My Philips DCM230 home stereo system wont produce any sound. The CD is playing, the voulme is on, and the mute is off. What could be the problem?
Your output I.C. might be faulty. Output I.C. is the one converting the audio from cd's,tuner,auxiliary to sound which passes to your speakers.
Since your Output I.C. is defective then the unit will not generate any sound even your inputs(cd,tuner,auxiliary) is working.
It is quite technical so I've advice you to look for a qualified technician to isolate the problem and do resoldering also for some dry joints on the main board.Dry joints also will might caused for damaged a parts.
Thanks for using fixya.
Jan 05, 2011 | Philips DCM230/37 iPod Docking Executive...
No sound
Make sure the speaker are plugged into the "audio out" ports. Black negative, red positive.
If a dvd players or other system is hooked up, the speaker should hook into that unit, then the unit is hooked to the auxiliary port(s), or the proper ports for each unit: ex: cd/dvd should be plugged into vd/dvd; same for vcr, game system - auxiliary is for pretty much any unit not listed on the backing of the receive - however, some units will still work while plugged into the ports other than auxiliary.
Make sure the receive is selected to the desired device.
If you simply have the speakers plugged into the speaker ports, make sure the speaker themselves are still good - try hooking them up to another source such as a a dvd player equipped with surround sound or speaker adapters that will suffice your speaker wiring.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Jun 28, 2010 | Onkyo TX-SR606 Receiver
Jun 30, 2009 | 2008 Mazda Mx 5 Miata
Ipod input for sa-eh760
You can plug the Ipod into the mic input , to do test recording. But the result wont be great.
To listen the Ipod in your stereo you should plug the Ipod into the Auxiliary input on the stereo.
Naturally you do not need any dvd.
Here is the adapter: 1.5M 3.5mm Male to Male AV Audio RCA Y Adapter
Feb 17, 2009 | Technics SCEH790 CD Shelf System
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
T v and home theatre sony bravia
As most home theatre systems offer no analogue audio input and only use the audio coming from the dvd being played the short answer is no.
If your home theatre system has a digital input and the tv has the corresponding output then yes you could me able to connect the two. Otherwise you could try to get hold of a analogue to digital converter and convert the tv's audio out to digital.
Jan 11, 2008 | Audio Players & Recorders
Switching on the auxiliary input
Best of Luck.
Nov 12, 2007 | Kenwood eXcelon KDC-X579 CD Player
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Ekse
 Grubhead
Grubhead
