I can not find any info on the model# N8368S-7. I am looking to find out how to repair the oven especially but both issues. And I have found no luck finding a manual either.
I thought my 1972 GE was old! You need to have it serviced by an elderly gas appliance technician. The pilot jets and thermocouples and hoods can be cleaned by you, but nothing else. It also needs testing for the gas pressure in your house, using an old liquid manometer and adjusting accordingly..
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk00ua74SGBTvbwmaH313ngpsSzTOPQ%3A1613522573202&ei=jWYsYILsC42otQWv4pu4AQ&q=Wedgewood+N8368S-7
SOURCE: Oven will not light
Go to partselect.com and look for a ignitor.
When on this site... you will be asked to put in you model # which you will find in the drawer below oven.
This is a very simple project which should be about half hour to replace.
No electrical to turn off, no gas to turn off. Just a screwdriver, and the job is finished
SOURCE: got a problem with a
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
SOURCE: Maytag stove model mes5552BAB. Display
When the display on units like this stop showing it is usually as a result of a minor problem from the control board. The control board is responsible for the display and atimes due to a power fluctuation an IC could get burnt and therefore affect the screen display.
If you have the technical know how you can trace the burnt out IC on your own but if not call an expert to check if the IC is one that can be replaced.
Although you might want to test to see that the unit is functioning so as to determine if the entire board is bad or its just the display.
Hope this solution has been helpful?
Thank you for visiting FixYa.
SOURCE: I have a Whirlpool range
The model number which you provided for your whirlpool range unit is absolutely correct.This is the correct model number.-------- But actually, this model is stopped being made by the company and its user manual has been discontinued.To get the user manual, the whirlpool itself is good open.Clickthis link below to directly get whirlpool contact details:--- https://www.whirlpool.com/contact-us/ ----------------- But its parts schematics is available:--- Click this link below for Whirlpool WBP36500 PARTS schematics:--- http://www.youserguide.com/wiki/Whirlpool_WBP36500_parts-001 ---------- thanks.Helpmech.
SOURCE: amana arg7102w gas range broiler
heatman101
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
