Question about Whirlpool Dishwashers
My whirlpool quiet partner II is stuck on clean. what keys do I punch to reset this machine?
    Top Expert:
  • Whirlpool Master
  • 55,370 Answers
The problem may be stuck or failed "keye" or a stuck cycle timer or both.
Posted on Dec 17, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Dishwasher (whirlpool quiet partner II)
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
Posted on Sep 09, 2008
Paulo
  • 188 Answers
SOURCE: whirlpool quiet partner II top rack sprayer doesnt
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Posted on Apr 03, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: clean light is flashing
This can be a common issue with some Whirlpool manufactured dishwashers. This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Nov 02, 2009
Testimonial: "Worked perfectly! Thank you."
Anonymous
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
mail4tijani
  • 70 Answers
SOURCE: How do u unlock the whirlpool quiet partner II
Hi, these dishwashers have a child safety lock so kids can not play with them. To unlock, just push and hold any button for 5 seconds to unlock.
Posted on Jun 28, 2011
Whirlpool quiet partner ii clean light flashing 7 times. I installed a new heating element and reset the code, and it still flashes 7 times
Check the main control for the heater relay, this may be faulty and the cause of your issue. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 30, 2016 | Whirlpool Dishwashers
Whirlpool quiet partner II starts and stops. What should I check?
the first thing to do is unplug it for 3 minutes then check to see if it reset by running
Jan 07, 2018 | Whirlpool 24 in. DU951PWB Free-standing...
I have a Whirlpool Quiet Partner II that used to
ok first prime the sink then put a table spoon of tang in dispensor then run the unit this will clean the dish washer
Jun 30, 2010 | Dishwashers
I have a whirlpool Quiet partner II. It will not fill w/water.
ck the float in bottom of tank . it may be stuck n the up pos .. moce it up and down and listen for click of the sw .. very common . also the water valve may have failed and it will need replaceing . mm
Dec 07, 2009 | Washing Machines
Whirlpool Quiet partner II
ck the float / it may be stuck . / water valve may have failed . mm
Dec 07, 2009 | Dishwashers
Whirlpool quiet partner II dishwasher is leaving chunky residue on dishes
I H AWHIRLPOOL DASHWASHER MODEL # DUII45XTPB6 quite partner ll I lost my manual , Im trying to acess the error codes . or Im trying to get the diagnostic codes to start . Hope some one can Help""""""
Oct 19, 2008 | Whirlpool Dishwashers
Whirlpool Quiet Partner 980
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Bruce Denton
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
